Cleaning Enclosed Trailer
What does everyone use to clean and wax the exterior of your trailer?
Mine is an ATC 36' gooseneck with a white exterior. I've neglected this trailer a little bit as I've owned it form almost three years and I've never waxed it.
It's an all aluminum trailer and I hope to keep it for many years.
Don't know about Skygeek, I should try that next time I wash a trailer of mine. My current one is so big, I have it done at the truck wash.
When I had a 40' gooseneck, I would wash it down with regular car wash, then use LA's Awesome to remove the "graying" that built up on the sides. Then I would wax it with Mequires car polish.
It would clean up really well, so the time is well worth it. The first step (wash) was fast, maybe a 1/2 hour. The second was the hardest, depending on how much staining is present. The third was an easy, but time-consuming, job. It is is sunny, your eyes will be hurting because of the brightness of the white trailer sides.
A friend told me and demonstrated a cleaner named "Korkay" on my trailer. It was marvelous. Just spray it on about a 1 foot square, let it set for about 10 seconds, then wipe it off. No fuss, no muss. I did my whole trailer and it was a black streaked mess, but afterwards it was clean again.
Just Goolge Korkay cleaner for a distributor.
My 20' enclosed trailer is black. I was told that most all enclosed trailer manufacturers use automotive-grade paint on the aluminum skin.
The nose of the trailer will get the most abuse so use a good quality car wash soap, rinse well and then towel-dry. Use a good quality auto wax or even a paint sealant. For the sides and rear ramp you can use a spray-on wax.
I use Griot's Garage Paint sealant on my trailer. This typically lasts a full season.
Once I apply the sealant, I'll use their Spray-On Wax after washing the trailer. It's easy to apply and provides a really nice shine. I also use both products on my Silverado tow vehicle (also black)
Overall the trailer is more oxidized than I thought. Although the wax helped I need something a little stronger to bring all the shine back.
Thanks everyone for the replies.
