Castrol SRF brake fluid
Old 01-21-2013, 02:11 PM
MarkDFW
MarkDFW's Avatar
Default Castrol SRF brake fluid
After boiling Motul 600 a couple times in the past year, I am biting the bullet and going with SRF this season based on the rave reviews i have read. I will also be running stoptech ST60 BBK up front and stick with stock rear setup. Carbotech xp12/xp10 pads are working great and centric rotors in the rear are holding up well.
Curious how often those of you with a similar setup have to bleed brakes? I saw a couple threads where guys said they could bleed once a year with SRF. That sounds like a pretty amazing claim. Is SRF that good?
Old 01-21-2013, 02:24 PM
63Corvette
63Corvette's Avatar
Mark do you have cooling? you don't say, but if you are having that much trouble then I would think you will need cooling even with your new mods. I run SRF in my racecar, and Stoptechs on the street (against my sanctioning organizations rules), so I can't comment directly on your issue.
Old 01-21-2013, 02:50 PM
MarkDFW
MarkDFW's Avatar
I was going to put in cooling ducts, but I was told by my shop they won't fit. I had an aftermarket stall converter put in and it required adding a tranny cooler. Apparently the cooler gets in the way of putting in brake ducts. They said they could move it, but then it won't cool the tranny as well. Hello rock and a hard place...
My hope is the ST60 BBK will dissipate heat much better to where I could run the motul 600, but I'd just assume go with the SRF based on what I've read on here. Much higher wet boiling point than the motul 600.
Old 01-21-2013, 03:40 PM
MYRX
MYRX's Avatar
I have been using the SRF for 3 years with great results. I don't W2W, just TT with CL pads. Basically I bleed in Feb, and I have been good for the year as stated in some of the post you read. I will point out that I only do 5 - 6 weekends per year. Just my 02.
Old 01-21-2013, 10:21 PM
Soloontario
Soloontario's Avatar
I have tried Motul 600, High temp Wilwood, ATE Superblue, Elfalub and Castrol SRF. The Castrol is absolutely the best of the bunch and by quite a bit. Couldn't go back now and given the money I spend on pads, I can't complain about the fluid cost. I too don't bother bleeding the brakes during the season (although I do have cooling ducts)
Old 01-21-2013, 10:23 PM
MarkDFW
MarkDFW's Avatar
Do you run a BBK or stock calipers?
Old 01-21-2013, 10:35 PM
68sixspeed
68sixspeed's Avatar
St. Jude Donor '10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20-'21-'22-'23-'24
my same experience and use... I do have the quantum/lambert cooling hoses on the front, so I think the OP should be able to run the same?
Old 01-21-2013, 10:44 PM
MarkDFW
MarkDFW's Avatar
I was told the LG brake ducts wouldn't fit without moving tranny cooler.
Old 01-21-2013, 11:04 PM
68sixspeed
68sixspeed's Avatar
If your cooler is by the radiator it shouldn't matter-- this kit uses the factory plastic duct from under the front fascia to just in front of the a-arms, then extends it with hose and an aluminum adapter to cool the brakes much better.
http://www.lapponline.com/index.php?...60061e6de97ac1
-Dan
Old 01-22-2013, 12:03 AM
Supercharged111
Supercharged111's Avatar
WTF kind of hack job did they do? I thought C6 brake ducts drew their air from an NACA duct on the bottom of the bumper? Even on the C5 they're way out to the sides beyond where you'd stick a trans cooler. Can you monitor your trans temps? Do you have any wiggle room with them?
Old 01-22-2013, 08:32 AM
rfn026
rfn026's Avatar
Motul 600 has one of the highest boiling points of any brake fluid - 590 degrees. If you're boiling that then you have an issue. It might be the way you're braking. Do you stay on the pedal for a long time?
Here's my recent blog posting on brake fluid. Enjoy.
Richard Newton
Facebook
Old 01-22-2013, 08:40 AM
ErnieN85
ErnieN85's Avatar
best tip go over to LG in Plano and see what they can do
Old 01-22-2013, 09:24 AM
MarkDFW
MarkDFW's Avatar
Richard Newton
Facebook
I run advanced HPDE and while I'm sure I can improve, my braking technique seems sound. I'm at threshold braking almost immediately, then ease off as I approach apex. I still do most of my braking in a straight line, but I'll do a little trail braking.
I think the difference with the SRF is the wet boiling point. I know plenty of good drivers who seem to boil motul 600 after a few days at the track. I'll be interested to see how long I can go without bleeding the brakes with SRF plus ST60 BBK up front and basically stock rear setup. I plan on around 8 HPDE this season and I'll keep everyone posted.
Old 01-22-2013, 09:39 AM
MarkDFW
MarkDFW's Avatar
I hear you. I'm going to see how far I can get with the SRF plus ST60 setup. If I boil SRF this year, I'll have them figure out what needs to be done to cram cooling ducts in there.
To Castrol SRF brake fluid
Quick Reply: Castrol SRF brake fluid
