ATEQ VT15 vs ATEQ TPMS SENSOR TRIGGER
I just bought a set of track wheels and tires for my C6. They are coming from the PO with TPMS (2007 just like my car). I'm a little confused as to which tool I need to connect the (two sets) of TPMS to the car..
ATEQ TPMS SENSOR TRIGGER - According to Tirerack "The ATEQ TPMS Sensor Trigger tool enables the vehicle to recognize a newly installed sensor and is excellent for drivers who have two sets of tires and wheels for their C6 Corvette or Cadillac XLR and need to register their TPMS sensors when changing from one package to the other."
--or--
ATEQ VT15 - again according to Tirerack "Easy-to-use, simply position the two-button triggering tool close to the sensor and tire side, then press the left button. LED lights provide feedback while in use. A yellow LED light is illuminated while the tool is transmitting. A red light will illuminate when the battery is low."
I've seen the VT15 for sale on the forum, but I can't remember ever seeing anybody selling the Sensor Trigger Tool...
I need to get the car to recognize the new sensors (first time I install the wheels) and then I need to be able to switch between the wheels and reset the car to recognize the currently mounted set.
Any advice or help on this is appreciated....
--or--
Don't have any experience with those but I do have the higher model Ateq VT30 and it is great. A little bit more money but i believe it has a lot more capability. LCD screen that actually shows you all of the TPS info i.e. the unique tps id number of the individual the sensor that you are scanning as well as the battery strength of the sensor. As you go through the activation process it stores all of the info from each sensor also, so you can recall this. One of the nice things about this is that when you come off the track it takes a bit of time to check air pressure on each individual time using a hand held gauge. I just hop out of the car, grab my VT30 and walk around to each wheel and scan the tps. The VT30 reads the sensor and stores each individual tire sensors information including the tire pressure which it reads to 1/100 of a psi i.e. 36.48 PSI and also the tire temperature (which is not as accurate are using a pyrometer but it does give you a good indication of what is going on). You then have some time to take off your helmet, unwind, drink some water etc. and can just recall the info on the VT30 when you are ready to start adjusting air pressure etc.
--or--
--or--
Ian
I just got the Cub tool from Tire Rack to program my 2nd set of TPMS on my new wheels for my 05. It does read back the tire PSI as well, though I don't really care about this feature as all I want to do is reprogram when I switch my wheels and tires. The Cub is only $60 so that is what made my decision easy.
