Anyone track without tow hooks?
I know this is a stupid question but does anyone track without tow hooks? I've done 11 events in my C5 Z with no incident. Not to say I couldn't have one. I've down probably close to 70 events or more total and only ever been towed once and I'm not sure the tow hook was really needed.
90% of the tracks I go to do not have any kind of gravel pits. Is it easy to tow if you don't if that is the case?
I really don't want to take my front bumper off plus I have a Vararam and putting a tow hook on with that is a pain.
Still, I know having a tow hook makes it that much easier and quicker. How exactly do they tow if you don't have one?
I do not race and only do DE events. Car is still driven on the street.
Thanks.
Thanks.
Thanks.
Thanks.
Tow hooks = insurance. Have had them on my car for several years but have had no need to use them. But, if you do have an off track event, the likelyhood of the track crew retrieving your car without further damage is much higher. Having tow hooks gives me a warm fuzzy.
I have been there rain day, empty track having a blast sliding the car around got cocky and this happened. It sucks watching them try to drag your car out on suspension stuff it took hours to clean this clay off even with the mother of all pressure washers at the track.
Hey I didn't think about that. I just recently installed a Drawtite hitch on my car to pull a tire trailer. Can this now suffice as a rear tow hitch?
my Z06 is lowered and I ran out of gas and they wanted to tow me back on the flatbed......... got them to bring gas instead............ very embarrassing......
I added them after seeing fiberglass body panels destroyed by a wrecker at the Glen. Their purpose in life is to remove the car asap, not to make sure they don't damage anything. Have not had to use mine so far ... knock wood.
Sounds like you're tempting fate.
I've had one on both the front and rear of my car for 3 years and I've never needed to use either, but I know my time is coming.
That should be fine. There are eyelets available to slip into your receiver. Somewhere I read some specs on tow hooks/eyelets and I think a 2" x 2.5" hole is recommended (mandatory in some cases). Remember, the tow truck operator needs to pass a hook through the eyelet. I still have a couple tow hooks available for 89-96 C4s to those of you who could use one.
Track Junky
I haven't installed them yet, but probably should. They would have come in very handy when I popped my motor at HMS last year. Took over 30 min putting the car on a flatbed without the hooks.
You will want a front tow eye/rope, if, for example, your ignition switch decides to bite the bullet after you stall after a spin. It will avoid a flatbed ride back to the paddock.
When getting pulled, feather the brake so that the rope stays relatively tight, or else you could get the rope caught up in a tire (when the tow truck decides to stop/slow down) and damage the front fascia (or if you are fancy, the front splitter and carbon undertray as well).
Perfect example was this weekend in Houston at MSR: soft ground but dead grass. I had two offs and started two fires because I was stuck and nearly stuck. Thankfully I didn't need a tow just a push but the tow hooks were there just in case no matter which way I was pointing. I've seen fires consume half an acre on a windy day in nothing flat. If the car were stranded it might become a casualty.
In my case that means a second extinguisher: I already have one bolted in that when activated will spray the drivers feet/firewall area and a second nozzle under the hood. I do not though have a second one that I can unbolt and try to put out a grass fire, may need to think about that and pull out some ballast
I would rather have a dedicated front tow hook than have the track workers "find" a spot to hook their cable/strap/ or gulp....chain hook on my car.
My track car these days is a street car. So I didn't want to do too much that couldn't be undone. I run the Phoenix folding tow hook and keep the "eye" in my glove box in case I need it. Clean install but does require that you remove the bumper cover and drill the bumper channel. I found another intake grill and trimmed that rather than my original.
Since we are on the subject...here are some of my install pics.
Received 8,929 Likes
When the engine blew on my Z I didn't have a tow hook on the car. The tow truck driver at the Glen was very careful with my car. They lifted it at the rear wheels by sliding two bars under the car and then widening them to the tires, then the outside of the bars moved around the outside of the tires and clamping them between the two bars. Then they tied the two sides together and lifted the rear of the car just far enough the wheels and bars were off the ground.
Since then I have installed a rear toe eye but that doesn't do much good when they are trying to toe you back to the pits. Being towed backwards is no fun.
Bill
Bill
No hooks on the front of my '87 as there is no easy way to mount one there.
I have a trailer hitch in the rear and I have a ring that mounts to the hitch.
