Best camcorder mount not GoPro
Old 01-24-2013, 12:27 PM
froggy47
froggy47's Avatar
Default Best camcorder mount not GoPro
Correct me if I am wrong, but the GoPro is not a standard mount at the camera?
If so what's a good one, I have a Canon Camcorder (Vixia R30) & will mount inside (as the lense does not have protection).
Something to stick to side or back window.
Old 01-24-2013, 03:31 PM
ktlocklear
ktlocklear's Avatar
I use the Fat Gecko Mini Mount. Works well inside and out.......
http://delkin.com/i-5829839-fat-gecko-mini-mount.html
Old 01-24-2013, 04:27 PM
mountainbiker2
mountainbiker2's Avatar
I hope you post your videos when you get them.
Steve A.
Old 01-24-2013, 05:35 PM
froggy47
froggy47's Avatar
Do you use single/double/triple cup Fat Gecko?
Sure will post up Steve.
GettReal
GettReal's Avatar
I have the go pro stuff now but also have this mount. This is Crazy Strong
http://www.vacuummounts.com/prodpics.php
Old 01-24-2013, 05:45 PM
froggy47
froggy47's Avatar
I like dealing with one cup instead of 2 or 3.
Thanks.
Old 01-24-2013, 06:59 PM
Han Solo
Han Solo's Avatar
I have used this mount with a Cannon 720 IS point and shoot. Not sure if it's up to camcorder weight but it worked fine for what I mounted on it. It says it's rated for cameras up to 3 lbs.
Amazon Amazon
Old 01-24-2013, 07:26 PM
froggy47
froggy47's Avatar
http://www.amazon.com/gp/product/B00...ls_o04_s00_i00
The camcorder is about 10 oz on my postal scale so that should be good.
The base on this one you use looks like the GoPro base almost exactly.
THX!
Old 01-24-2013, 10:06 PM
TravisD
TravisD's Avatar
You can get the GoPro tripod mount for $7. They're a great basis for custom mounts since you can attach them to anything with a 1/4-20 thread.
Going the other way, the GoPro suction cup mount is actually from Panavise. They sell it in a standard tripod mount:
http://www.bhphotovideo.com/bnh/cont...G&Q=&A=details
Old 01-25-2013, 12:03 AM
froggy47
froggy47's Avatar
Yes, I saw that Panavise has a huge product line & it's on Amazon with free shipping & lots of good reviews.
Think I'll go there.
Thanks all!
Old 01-25-2013, 03:26 PM
GS023
GS023's Avatar
Default mount
Sorry to hijack. I am using a small Sony camcorder and looking at a couple of the mounts it looks like with the angle of the windshield inside that the camera would not clear. I ordered the fat gecko dual cup. Will let you know how it works.
Old 01-25-2013, 03:56 PM
Han Solo
Han Solo's Avatar
If you want an example of steadiness on the Panavise you can look at this pic-n-pic video I did using it on the side window. The inset video focused on the driver is a Cannon 720is mounted on the Panavise. The main video is another 720is on a custom mount I made. The 720is specs says it weighs 7.05 ounces without batteries.
Note: the Panavise is not good for mounting a standard size camera with a bottom mount hole to the windshield. It'll work fine on the side or rear window if you have a remote to operate the camera with. I also did not like the 3" extension for the panavise. It seemed to make it less stable.
I now use my Panavise on the windshield with a little 808 #11 camera velcroed on a plastic block I drilled and tapped 1/4-20. It is dead steady for that but those cameras only weigh about an ounce.
Old 01-25-2013, 04:25 PM
froggy47
froggy47's Avatar
Thanks all, I ordered the Panavise & ext.
We'll see.
To Best camcorder mount not GoPro
Quick Reply: Best camcorder mount not GoPro
