Got my seat, brake fluid & pads. Anything else?
Looks like I'll make my first open track this Saturday.
I get my Recaro installed tomorrow and then Friday some Hawks + pads and Castrol SRF.
I have an oil catch can on the way with some Goodridge SS brake lines.
The next set of pads I will order is xp10's and 8's from Carbotech.
I like shopping around on the forum and finding deals so what should I look for next? Brake coolers?
I'm going to hit every HPDE I can at the four local tracks here in the NW. There is no doubt in my mind that I am going to love it.
Thanks guys!
Thanks guys!
Thanks guys!
Thanks guys!
Without trying to sound like a jerk, a good quality and good fitting helmet.
After that you'll need your wallet, checkbook, credit cards, retirement account and kids college fund - speed is not cheap. It is a blast though. Enjoy.
Thanks guys!
Thanks guys!
Did you get harnesses with your seat or planning to use the 3-point? If you got harnesses, which you should with a good seat, then you also need some type of hans (doesn't have to be the HANS brand as there are some hybrids that have great reviews).
Pick up a gopro if you don't have one...much cheaper to re-live it the second time and they can be good learning tools.
+1 on the Ranger flush. The slave gets awful hot and you get a lot of clutch lining debris that get packed in there on track days. Use any reputable brand DOT 4.
Cost < $10
Time < 10 minutes
Cost < $10
Time < 10 minutes
I did buy a helmet today and I love it! Great reply.
Doesn't hurt to do a "ranger flush" on the clutch. The brake ducts mentioned already you will def want, for brake and hub/bearing life....skf's aren't cheap.
Brake cooling is a must. I am also looking into some bigger front brakes. Brembo. $$ Jeeeeez $$ but
Gopro. Yes BUT have you heard of Replay? Check this camera out:http://replayxd.com/product/replay-x...camera-system/
It is more aerodynamic so it cuts the sound of wind and has some awesome attachements. I am also looking into this.
Oooh thanks for that tip. Hopefully the mechanic at Speed Secrets knows all about the ranger flush. I will ask him to do that, thank you.
check this thread, may not need everything those guys listed for 1st time, but it does contain some things ya may not be thinking of:
http://forums.corvetteforum.com/auto...e-weekend.html
I am going to use my 3-point for now then get a stabilizer bar to attach the HANS. Thanks for the brand to look into.
If you have an iPhone- Get Harry's Laptimer app ($20) and a RAM mount. Why get just video when you can get data ?
MAKE SURE you have a QUALITY torque wrench. Hit those lug nuts before EVERY event at your HPDE-and most of all have fun !!
