C6 coupe: 315/30-18 square set-up?
I’m looking at ordering a set of track wheels for my C6 coupe that I acquired this winter. Looking at the tire options and potential sizes that would work are dizzying. Originally, I was thinking of going with a staggered setup with R888. However, after emailing John at CCW, I have been thinking a square (tire) setup would open my tire options up significantly.
Unfortunately, my all-time favorite bang-for-the-buck track tire the Toyo RA-1 doesn’t come in the right sizes. My next favorite has to be the Nitto NT01 in a 315/30-18. I’m not interested in running anything equivalent to a Hoosier R6 or more aggressive until I familiarize myself with the car.
Has anyone run a 315/30-18 front and rear? I have read about inner fender liner rubbing issues with this setup but only in one thread from a couple of years ago. Any other fitment issues?
Does the TC/ABS work with a square setup?
Thanks!
Thanks!
Thanks!
Thanks!
CI 7-8 Veteran
St. Jude Donor '07-'08-'09
I run 315/30-18 all around on my C6. I use a 1/4" spacer on the front to minimize rubbing on the inner fender. You can also put stops on the steering rack. Most rubbing occurs in the paddock when making sharp turns. You'll have to turn the TC off. No problem with the ABS.
Thanks Dirk! I will try and get in touch with Livermore. Sounds like he will have answers. I'm really looking for people with real-world experience.
KY-T: Great looking car! Is that a GS? Are those C5Z wheels? My car is a Z51 coupe. I think my fitment is different?
Jon
Jon
315/17 NT01's on 99 C5 with no issues. Doesn't even rub in the paddock like the the Michellin 305 slicks did. Understeer isn't a problem Start the video at around the 5 minute mark.
Thanks!
Thanks!
just described.
CI 7-8 Veteran
Those are C5Z rear wheels.
I have a narrow body c6 like you and I have CCW track wheels. Max front width CCW will make for this car is 10". I've put a 315 equivalent on it and it's a squeeze and it rubs but it can be done. Note I have lots of camber, ground fender lips and liners, and yes it rubs on full lock with brake ducts and yes I've cracked a fender when I had a hard off after losing brakes. The tire I was running was a 305/660/18 conti slick which looked identical in width when placed next to a Hoosier 315/30/18 r6 but looked 1/4" taller. That extra height didn't help and may have contributed to the cracked fender. Point is its really really close with the narrow c6 front and may not be worth it to you given what I
just described.
just described.
Thanks for the feedback. Even with what you described, I'm leaning towards going with a 315/30-18 in the front. The only thing that gives me pause is the listed width of the NT01, which seems to be about 0.1" wider than other brands in the same size. Rubbing at full lock isn't a huge problem, I'm more worried about rubbing when driving at speed. Which, as I think I am beginning to understand, maybe isn't that big of a problem?
Any other narrow body C6 owners have experience running a 315/30-18 in the front? I think it is fairly established that the C5Z handles that size in the front no problem.
Jerry,
CI 7-8 Veteran
