Track Info, Torque PDF's, etc by David Farmer
Old 02-10-2013, 08:21 AM
davidfarmer
Support Corvetteforum!
davidfarmer's Avatar
Default Track Info, Torque PDF's, etc by David Farmer
haven't posted in a while, they get muddled up over time on my Facebook page. However, you can always find them by going to my Facebook page, and scrolling down (and scrolling and scrolling).
Print both side, laminate, keep in your car or tool box!
www.facebook.com/DavidFarmerRacing
https://drive.google.com/file/d/1DHs...?usp=sharingc5 trouble codes
https://drive.google.com/file/d/1AuH...?usp=sharingc5 Fuse Layout
https://drive.google.com/file/d/0Bx3...a-LuuxhGSEzK9Q c5 complete parts list
https://drive.google.com/file/d/1gdi...?usp=sharingC5 Torque Specs
https://drive.google.com/file/d/1GKN...?usp=sharingC6 Trouble Codes
https://drive.google.com/file/d/1fpP...?usp=sharingC6 Automatic Torque Specs
https://drive.google.com/file/d/17rb...?usp=sharingC6 Manual Torque Specs
https://drive.google.com/file/d/1NLL...p=sharingC6Z06 Torque Specs
I have the alignment guide, Diff fitting guide, etc still available. If you can't find them via my Facebook page, let me know and I'll add them here.
DavidFarmerRacing@gmail.com
As always, I also have Vinyl Stickers and am available for Alignments, suspension installs/repair, corner balance, driver coaching etc in NC and the tracks that surround us!
The following 2 users liked this post by davidfarmer:
383 (02-13-2017), Kubs (10-06-2021)
Old 02-10-2013, 08:47 AM
PaConehead
PaConehead's Avatar
I just used this site last week to check some C5 torque specs - thank you !!!
Old 02-10-2013, 09:49 AM
JDIllon
JDIllon's Avatar
David!! Thanks again for posting this info!! For those of you that do your own work on the car!! this is great info to have and use. JD
Old 02-10-2013, 09:52 AM
YYZ06
YYZ06's Avatar
Good stuff David. I'm a Facebook conscientious objector so if you wouldn't mind linking them that would be great. This'll go in my racing links file.
Old 02-10-2013, 03:34 PM
fcarga
fcarga's Avatar
Ditto to all of the above posts and thank you for taking the time!
Old 02-11-2013, 09:22 AM
davidfarmer
I'll try and post the rest of the links later. I hope you aren't a "Dropbox" objector?????
Old 02-11-2013, 09:47 AM
TheKomoman
TheKomoman's Avatar
St Jude Donor '13
Thanks David - I object to neither Dropbox nor Facebook (though I'll admit that one makes me wince) so I grabbed them. Thanks as always!
Old 02-11-2013, 10:19 AM
Scooter70
Scooter70's Avatar
Joe,
I saved all of Dave's documents to my phone so I always have them with me at the track. Junior is all over Facebook so you could have him look for you though.
Old 02-11-2013, 01:29 PM
YYZ06
YYZ06's Avatar
Never heard of it... Honestly, I'm no Luddite... I'm sure Matt will educate me.
Originally Posted by Scooter70
Joe,
Thanks Matt. I'll have to look into Drop box. I saw you sent me an invite.
Old 02-11-2013, 02:17 PM
davidfarmer
https://dl.dropbox.com/u/1634366/accusump.pdf accusump fitting for LS engine
https://dl.dropbox.com/u/1634366/align.pdf my basic alignment measurement guide
https://dl.dropbox.com/u/1634366/apr-wheel-stud.pdf APR Studs info
https://dl.dropbox.com/u/1634366/camberplate.PDF camberplate info, just basic FYI
https://dl.dropbox.com/u/1634366/diff.pdf diff fitting info for coolers
https://dl.dropbox.com/u/1634366/FluidairParker.pdf great Parker fitting catalogue info
https://dl.dropbox.com/u/1634366/quartermaster-C5.pdf Quartermast clutch install info
https://dl.dropbox.com/u/1634366/SuspensionGuide.pdf basic chassis setup guide-quick reference
https://dl.dropbox.com/u/1634366/T-5...ice_Manual.pdf T56 repair manual
https://dl.dropbox.com/u/1634366/weatherhead.pdf Weatherhead brake fittings 1-NAPA
https://dl.dropbox.com/u/1634366/weatherhead2.pdf Weatherhead brake fittings 2-NAPA
old stingray (04-14-2016)
Old 02-11-2013, 02:18 PM
davidfarmer
gtw, Dropbox is great for 1. sharing files 2.syncing files 3.backing up files (depending on storage needs).
Carbonite is cheaper if you need to back of lots of data (I have 400gig on Carbonite, movies, music, docs, etc), but Dropbox is awesome for files I use daily!
Old 02-11-2013, 03:06 PM
Scooter70
Scooter70's Avatar
If anyone wants a Dropbox account, click this link: http://db.tt/yArBZzU
Old 02-11-2013, 05:02 PM
el es tu
el es tu's Avatar
David does some great work with vinyl:
the mustache may look easy to cut, but no way would I have attempted to make that monocle!
Old 02-11-2013, 05:34 PM
shakedown067
shakedown067's Avatar
St. Jude Donor '12-'13
We need to create some facebook tabs for that there page!
Old 02-11-2013, 06:26 PM
davidfarmer
If I've missed anything, let me know. I'm in the north Charlotte area, so if anyone needs anything, please let me know. My kids are getting older, and I'm ready to start turning more wrenches!!!!!
Old 02-12-2013, 09:21 PM
Z06Tracker
Z06Tracker's Avatar
David is a great supporter of the Corvette community, and can help you with many of your Corvette needs.
Old 02-12-2013, 09:47 PM
DansBlkonBlkZ06
DansBlkonBlkZ06's Avatar
David,
Good to know you have more time this year. I'll need a tech and alignment done next month. I'll need some numbers and TT3 stickers too. The vinyl work you did on Morris' car is awesome. I'm also thinking about the Pfadt Stage 1 JOC suspension upgrade and want to get your thoughts on that. Thanks
To Track Info, Torque PDF's, etc by David Farmer
Old 02-12-2013, 11:32 PM
crimlwC6
crimlwC6's Avatar
Thanks! I need vinyl..pm you or what?
Old 02-12-2013, 11:56 PM
JETninja
JETninja's Avatar
WA Events Coordinator
Thanks David!
Old 02-13-2013, 10:51 AM
davidfarmer
Dan the JOC setup sounds like a great for the money, although coil overs would ultimately be a better option (I think you are talking about the shock/bar package).
just email me for any other needs DavidFarmerRacing@gmail.com
Quick Reply: Track Info, Torque PDF's, etc by David Farmer
