Does this indicate a bearing problem?
I attended a driving school at Willow springs last week and my car started making a metal to metal scraping noise under braking. I assumed that I had a pad failure or that I had burned through the pads.... But when I took it apart the pads were fine and it looks like the rotor is scraping against the brake caliper mounting bracket. Everything in th suspension appears tight. The only thing I can think of is that my bearings are going bad. Has anyone else experienced this?
Take the caliper off and then the brake disk and inspect the hub and bearing. Could well be the hub is cracked and the only thing holding the thing on is the caliper.
Wouldn't be the first time.
Received 8,919 Likes
Did you check the hub by rocking the wheel up and down with your hands at the 12 and 6 positions? Seems like something that is allowing that much rotor movement would also allow the complete assembly to rock up and down a lot.
Bill
Yes, I tried rocking the wheel up and down but there wasn't an noticeable play. I assume that it takes more force than that to make it deflect. I haven't taken the rotor off yet.... But I will before I drive it.
Sounds like you are on the right track Charlie. Buy the SKF hubs and consider replacing the other 3. We breaks the stock hubs on track especially with sticky tires. This is a known issue. Van Steel and hardbar sell the hubs maybe pfadt too. Hardbar loves the nordlock and hex bolts but they really are not necessary. The hex bolts are a nice conversioon however makes it easier to trackside service and the T55 size iirc is not that hardy when you have some age and grime on those old bolts. A nice air tool makes your life a lot easier when you do this job and the cheapo harbor freight ball joint remover kit works great!
If the caliper bracket is contacting the rotor, then there should be some damage on the bracket as well, from any contact. I would expect to see a groove, though, not smearing. Were the pads bedded (broken in) properly?
From the apearance, it looks something like what i experienced, a ball of rubber got thrown there and smeared on the rotor. when it happened, my ABS went nuts on hard braking in a braking zone.
I did a video, click below, on using the tool. Search YouTube channel.
I second Froggy's video. Helped me through it when I did ARP long studs on all of mine. I safety wired my hub bolts, though it's overkill for sure. Red loctite won't hurt. If they are a problem coming out later (they won't be) just add a little heat. You basically can't check the lowest bolt once the hub is back on, so I wanted the peace of mind since mine came loose on track and I lost the brakes.
If it is metal to metal what other piece of metal shows wear? that will give you a clue as to what is causing your problem. Usually metal to metal does not discolor, and you see fresh exposed and sometimes really rough gouges. All I'm suggesting is SKF hubs are $350 each and if the original isn't bad then replacing them won't cure your problem.
With the caliper off, that bearing should be as smooth as butter. The bearings get rough feeling long before the clearances open up. If the bearing is smooth and there is no visible wobble, look somewhere else. Did you put fresh brake fluid in before going, if not, maybe you boiled on one side and you now have air bubbles (on the other side so this one bites more for the same pressure. Also, if they are stock pads which I suspect they may be, you may have just overheated the pad material. That is what it more looks like vs bearing clearance.
I still think there may be some transient material, a rock or something like that that got inside and made that mess.
Track Junky
The bearing didn't feel rough. I am going to take the bracket off to see if I can confirm if it is what is rubbing. The pads are Carbotech XP-10's. I put new fluid in right before taking it to the track...But I will bleed the brakes because my pedal got VERY soft while at the track...but, I am not sure how that could cause this. I also checked for material stuck in the pads and nothing is there. While driving I can hear metal to metal scraping when the brakes are applied fairly hard. I am also going to check to see if there are any issues with the Caliper bracket or the mounting bolts.
