Help me with Canton oil baffle bolts 95 LT1
Old 03-03-2013, 04:26 PM
corvette95
corvette95's Avatar
Default Help me with Canton oil baffle bolts 95 LT1
http://forums.corvetteforum.com/c4-t...-these-go.html
Old 03-03-2013, 05:09 PM
TJM
TJM's Avatar
The bolts are likely for the windage tray.
Check Canton's sit see if you can see anything like yours.
May answer the question?
Old 03-03-2013, 08:16 PM
corvette95
corvette95's Avatar
I posted this on the other thread, the bolts seem to be mandatory to cut off with a canton pan, the person I bought the pan from must have sent me the cut off stock bolts and you dont use the stock baffle. Hopefully got it figured out, now just got to get the pan and gasket on it without crimping the gasket. Been trying for two hours.
To Help me with Canton oil baffle bolts 95 LT1
Quick Reply: Help me with Canton oil baffle bolts 95 LT1
