What are the best ride hight adjustment Bolts?
Old 03-04-2013, 04:23 PM
Charley Hoyt
Charley Hoyt's Avatar
Default What are the best ride hight adjustment Bolts?
I need to change the ride hight adjustment bolts on the end of my leaf springs....The rubber is warn down which is affecting the ride height. I am looking for something more durable than the stock bolts. Any ideas?
Thanks,
Charley
Old 03-04-2013, 07:57 PM
el es tu
el es tu's Avatar
the ones on the T1 springs, the ones on the hyperco springs, or if youre just looking for the bolts - hardbar or lingenfelter
I believe all are delrin
the poly ones that come as pad kits wear out very quickly
Old 03-04-2013, 10:24 PM
sperkins
sperkins's Avatar
Thanks,
Charley
Hardbar delrin. I have a new set if you're interested. $50 shipped.
Old 03-06-2013, 05:10 PM
VGLNTE1
VGLNTE1's Avatar
St. Jude Donor '14-'15
Grade 8 at a hardware store for 5$.
Old 03-08-2013, 02:41 PM
AzMotorhead
Support Corvetteforum!
AzMotorhead's Avatar
PM'd you Sperkins
To What are the best ride hight adjustment Bolts?
Quick Reply: What are the best ride hight adjustment Bolts?
