Brake fluid question...
Old 03-08-2013, 06:13 PM
Bedouin
Bedouin's Avatar
Default Brake fluid question...
I have a can of ATE blue brake fluid, 90% full, that I opened once briefly @ 4 yrs ago & it's been sealed up tight as a drum in my garage ever since...is it still any good or should I dump it?
Old 03-08-2013, 06:43 PM
el es tu
el es tu's Avatar
It should be useable, but whatever air was in the container will have contributed moisture to the fluid, so keep that in mind
EDIT: was looking further into this since I bought the same stuff recently - (have a local shop that sold srf and motul 600 a year or two ago... now only sells ate)
apparently ate only recommends keeping the fluid for a year after opening.
aside from that, for unopened stuff there should be a date on the lower side of the back of the can
Old 03-08-2013, 08:14 PM
Segond56
Segond56's Avatar
I would dump it, a higher boiling point BF has a tendency to absorb more moisture. Even if you had the lid on tight, moisture is evasive and I am sure has seeped into the container. Rather than run the risk of putting in bad fluid and have pedal issues into a stint on the track, for the 20$ get some Willwood or Motul 600 deg. fluid and call it a day.
Old 03-08-2013, 08:37 PM
Bedouin
Bedouin's Avatar
Thanks for the input guys...good risk vs; reward....think I'd better go new Motul 600 dot 4, just hate to waste stuff.
Old 03-08-2013, 09:52 PM
froggy47
froggy47's Avatar
Dump it.
Old 03-08-2013, 10:14 PM
naschmitz
naschmitz's Avatar
$15 for a new liter. Waste it.
Old 03-08-2013, 11:08 PM
sothpaw2
sothpaw2's Avatar
Use it for a fluid change in your old beater Neon.
Old 03-09-2013, 02:15 PM
froggy47
froggy47's Avatar
I used some old (sealed) brake fluid in my clutch system & almost ruined the seals because the fluid became "corrosive" to the seals somehow. After we did forensics on it, we determined it was 10 yr old fluid, there was no way to determine that on the metal can. It was never opened.
There is a thread for those interested & I think I did a video if you ck below.
Old 03-10-2013, 04:33 AM
rustyguns
rustyguns's Avatar
even unopened after 2 years they are trash !
To Brake fluid question...
Quick Reply: Brake fluid question...
