Is your car used for track? If so, did the spring make an improvement in handling? I have an 84Z51 rear which is close to 600 lbs.
First, my car is used for autox and track. The spring did improve handling and lowered the car as well. I probably wouldn't get one for street use but you can. If you wanted to use the 600lb rear spring you would probably want the 1000lb front spring. I'm sure vbandp could help with your decision.
