Brake bleeding question??
I just ordered a new set of Stoptechs for my car. What is the best method for bleeding the system after the install? Motive, pressure cap, vacuum system, etc?
Thanks,
Charley
Thanks,
Charley
Track Junky
You can try to gravity bleed the calipers initially to get them to fill up. Do it in pairs, open both bleed screws on each caliper and wait several minutes. Once they start to drip, they are mostly filled. Still need to bled the old school way after that, but it will fill them up with essentially no work.
