Wheel experts....I need your help!!!
Old 03-20-2013, 04:14 PM
CP Thunder
CP Thunder's Avatar
Default Wheel experts....I need your help!!!
Can anyone tell me the make and model of this wheel? There aren't any markings I can find on it at all and I need to find a new wheel half ASAP.
Thanks in advance!!
Old 03-21-2013, 09:45 AM
96CollectorSport
96CollectorSport's Avatar
Location: If you don't weigh in you don't wrestle Road America
Steve,
That kinda looks like the Kinesis K58 or K59 wheel, I did a little search and it doesn't look like they make them in 17" anymore.
Hope this helps.
Joel
Old 03-24-2013, 10:25 PM
CP Thunder
CP Thunder's Avatar
Yes I believe you are correct. No source found for a wheel half. Had a bead welded into it then knocked it down to straighten the rim.........switching to 18s soon so it doesn't have to last too much longer...........
Thanks for the input Joel...........Hopefully get to see you at R A again this year (but under different circumstances).
To Wheel experts....I need your help!!!
Quick Reply: Wheel experts....I need your help!!!
