Who's running Michelin Pilot Super Sports & what track psi?
Old 03-20-2013, 05:22 PM
Bedouin
Bedouin's Avatar
Default Who's running Pilot Super Sports & what psi?
Non-rft Michelin Pilot Super Sports & what psi? CA ambient temps in the 60*-80* range & car is a '12 GS, stock 275/18 & 325/19 sizes.
Old 03-20-2013, 05:33 PM
MarkDFW
MarkDFW's Avatar
Shoot for around 36 psi hot. I used them for several HPDE and 36 worked well.
Old 03-20-2013, 05:51 PM
Bedouin
Bedouin's Avatar
Good to know...where'd you start cold?
Old 03-20-2013, 07:34 PM
MarkDFW
MarkDFW's Avatar
29 front and 28 rear was an average, but depends on outside temps
Old 03-20-2013, 07:53 PM
rfn026
rfn026's Avatar
I like 32 psi hot. I start off about 26 psi.
The best way to check for optimum pressure is to get an average of inner and outer temperatures. That number should be close to what your center temp is.
If the center is 20 degrees higher then you have too much pressure.
Richard Newton
Car Blog Tech
To Who's running Michelin Pilot Super Sports & what track psi?
Quick Reply: Who's running Michelin Pilot Super Sports & what track psi?
