250 ft lb torque wrench suggestions
I will be working with the car on jack stands so not a lot of swing room or room to put a jack handle extension on.
I am strong enough to put 150/60/70 or so (without an extension)but I need to go 240 (Balancer).
Is there a wrench that has some "multiplier" on it to get to the higher torque values without having to muscle it?
I don't want to guess with my impact gun.
St. Jude Donor '10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20-'21-'22-'23-'24
there are gear reduction heads but I've done 250 ft-lb before - my larger torque wrench maxes at 260 and is about 2ft long, so that is only 125lb pull. If you can get the wrench in position to use your weight it shouldn't be an issue.
You won't get 250ft-lbs on that bolt. Just tighten it as much as you can with an extension on a breaker bar and it won't move. Every How-To on the subject says the same thing.
Put it in gear and parking brake on. I think I used 4th when I did mine and it held well. The clutch does often slip a bit, but it should be enough to torque down that bolt. FWIW, I use a matco torque wrench for high torque bolts.
Get a couple friends to hold the rear tires. At that point it's just a matter of picking the right gear to have just enough leverage against the motor, but not overcome the clutch grip.
Snap-on...expensive, but well worth it. I recently bought a 3/8" drive, and while I was on the (snap-on) truck, I had my fathers 1/2" drive checked for accuracy. It's been used routinely, by both he & I, since he bought it in 1962, without any servicing. It was still, dead-on accurate.
Also, be very cautious about how you use a torque wrench. Torque values are affected by handle length (no cheater bars!), clean/dirty & lubed/dry threads. If using crowsfoot attachments, the angle used, makes a difference. If you're going to use it improperly, there's no point in using one at all. Google "torque wrench, torque values, etc" for good information.
I have several torque wrenches, but my go-to one is the ATD 101. I recenlty had it re-calibrated and the main reason I sent it back was because the numbers are painted on so they tend to rub off. If I remember correclty I have sent it back twice for that reason. The customer service is first class and they have always taken care of me.
http://atdtools.com/101
My matco is a sweet tool, but I only use it for big stuff.
