SCCA Solo Car Class Question (C6)
Hello,
A couple questions for you guys that Autocross your C6:
Last season I was running in Super Stock (SS) as my only mods at the time were some slightly wider tires (Michelin Pilot Super Sport's) on stock wheels. However over this past winter I've added some mods (SS Brake Lines, Cold Air Intake...) which I think will bump me into Street Prepared my question is how do I know if I'm in SSP or ASP, when looking through the SCCA Solo Rule Book (http://scca.cdn.racersites.com/prod/...lo%20Rules.pdf) ASP Section (Page Page 188) Corvettes aren't listed yet when I look at the Past Solo Champions Section (Page 296) I see Corvettes. So can I be SSP or ASP? Which is better?
Also for those of you that read the new article in Solo Matters ( http://www.solomatters.com/2013/03/s...sal-explained/ ) about the Stock category phasing out R-Comp tires over the next tires does anyone know if that will also apply to the Street Prepared class, as currently Street Prepared I beleive has the same rules for tires as Stock.
Thanks,
Tom
Thanks,
Tom
SSP is a (relatively) new class, and that is where you run. Corvettes aren't listed in ASP anymore, so you don't have a choice.
As far as I know the rules that are being floated won't effect the SP classes, so they will stay with R comps.
With your level of mods you will get hammered in the SP classes. If you want to be competitive in SSP you need huge (T1 or bigger) sway bars, stiffer springs, wider wheels and tires, headers, a CAI, a bigger throttle body, a set of Moton or Penske shocks... and that's just the obvious stuff.. Better to put it back to stock and run there.
but it depends on the region, I have a VERY under prepared SSP car and I'm lucky if I have one or two guys (also under prepared) to race each month.
National events YMMV.
In the article I linked there are talks of a Limited Preperation and a Street Prepared, I was under the impression that there will basically be two Steet Prepared classes one for cars with R-Comps one without, but that article wasn't very clear on that:
The SEB does recognize that not everyone will be excited or even willing to give up the thrills that only R-Comp grip can produce. In an effort to give those participants a place to play, the Board is proposing a limited preparation ruleset for Street Prepared classes. This ruleset would allow vehicles prepared to the limit of the new proposal to compete in an appropriate Street Prepared class on R-Compounds. The limited preparation cars would run in a slower class than their SP classing. The SEB’s goal would be to place cars where they are competitive but do not become the car to have for the class.
In the next year I'm definitely getting a set of headers and a Johnny O'Connel/PFADT Stage I Suspension Package (sways + shocks), and I already have the CAI. You really think a bigger TB will be nescessary? Wider wheels and tires? I'm already running 285F and 345R how can I possibly go wider? Or do you mean make the jump to Hoosier A6's? Or a square setup?
How bad is PAX between SS and SSP?
YMMV?
YMMV - Your Mileage May Vary
I've seen people run 315 fronts and that would be legal for an SSP car, 345 is probably about the widest you can buy for the back.
SS Pax - 0.859
SSP Pax - 0.871
SS Pax - 0.859
SSP Pax - 0.871
I take it R-Comps are a must then to be competitive in SSP? What's the lowest cost setup for R-Comps wheel & tire size?
Pax between the two doesn't seem to huge what would the SSM Pax be for refference?
If you want to be competitive in SCCA, take off your new performance parts and go back to super stock. Seriously! If you want to be competitive in SSP, then round up about $10K and dont plan on using the car for much more than autocross. Reliability will go down too. So you will want to trailer it.
Think long and hard about your choice:
1. Be competitive and low cost in SS.
2. Have fun modding your car with the parts you want, but you wont be competitive in SSP.
3. Spend $10K, build (or better yet buy) a great SSP car. Have a TON of FUN with that car, but be prepared for drive train failures, and continuous money spend.
There isn't much middle ground between these choises. If you choose option two or three, 18" wheels in front, and 17" wheels in back is a nice set up. You get more side wall in the rear so that you get more forward bite on throttle. The 18" up front makes the car more responsive.
For the 18" Front and 17" Rear setup what wheel widths would you recommend front & rear? What about tire sizes?
I'm not sure which size wheels & tires people were using for the 18" 17" set up. Search for Alex Tzortis or Danny Popps set up tips. Also search for old ASP setup threads.
315 front and 335 rear is what my fuzzy memory recalls for tire size.
Tom
I think Joe Tharpe has 335/17's on f/r IIRC.
the c6 has much more fender clearance than the C5. I think Mike Johnson runs 18x12s on front, 18 x 12 or 13"s on back of his C6 Z06. He runs 335s on front, 345s on back, and Joe Tharpe runs 335s all round (in 17 inch variants). 17s should clear base C6 brakes but not GS/Z06
Its always better to post in an existing thread than to start a new one......so, here goes
I plan on setting up a C6 Z06 for SSP. I have some of the important stuff from my previous setup but i need more info on the rear spoiler and splitter allowances.
Can I add a ZR1/Z07 splitter to an 09'+ Z06?
15. Street Prepared 2014 SCCA® National Solo® Rule — 93 "Splitters may not protrude beyond the bumper"
Im guessing this means the answer is no...
C. Equipment and/or specifications may be exchanged between different
years and models of a vehicle if:
(a) the item is standard on the year/model from which it was taken,
and
(b) the years/models are listed on the same line of Appendix A, Street
Prepared Classes
Im also guessing this means yes because appendix A just lists (2005-2011) C6 chassis
So which is it?
Where do I get info on the rear spoilers? They seem to be home made. Are they braced under the bodywork to keep from eventually ripping off?
Aero is like the forbidden black art
and
Prepared Classes
So which is it?
I don't see why you wouldn't be allowed to run a ZR1 or Z06 w/ Z07Pkg aero (splitter, spoiler and side skirts) though I don't know how much benefit you're going to gain from the little ZR1 splitter/spoiler at autocross speeds.
