Which swaybars to use?
Old 04-11-2013, 08:44 PM
C U IN REARVEIW
C U IN REARVEIW's Avatar
Default Which swaybars to use?
I have a 05 z51,phadt featherlight coilovers,z06 swaybars,265/305 tires. What bars should I use to stiffen it up in the corners....primarily street driven.
Old 04-11-2013, 11:44 PM
db2xpert
db2xpert's Avatar
Pfadt light rate comp bars
Old 04-12-2013, 12:25 AM
Werks
Werks's Avatar
For street just leave the z06 bars on it and call it a day. Anything more is just spending money for the sake of spending it. You are not going to reach the limitations of the stock Z06 bar on the street with a small 305 DOT tire.
Old 04-12-2013, 02:47 AM
StreetSpeed
StreetSpeed's Avatar
Originally Posted by werks
for street just leave the z06 bars on it and call it a day. Anything more is just spending money for the sake of spending it. You are not going to reach the limitations of the stock z06 bar on the street with a small 305 dot tire.
100%.
Old 04-12-2013, 07:40 AM
C U IN REARVEIW
Old 04-12-2013, 12:41 PM
froggy47
froggy47's Avatar
I doubt your car has too much lean with zo6 bars, if you want more GRIP look at your alignment & tires, keep in mind there is no "free lunch" here.
You will be buying more tires as a price.
To Which swaybars to use?
Quick Reply: Which swaybars to use?
