Need replacement brake ducting
Old 04-16-2013, 10:33 PM
morris
morris's Avatar
Default Need replacement brake ducting
I need a reccomendation, my brake duct material is hosed basically the duct is torn in half. I am going to New Orleans Motorsports park on Friday so I need to come up with something I can find locally to replace the actual duct material. Does anyone have suggestions for something that will work?
Its a C6 Z06
Old 04-16-2013, 10:58 PM
Corvee
Corvee's Avatar
Its a C6 Z06
The hose or the brake duct itself? I have found fire proof hose in various lengths and sizes at a local aviation parts supply house. Check listings near a major airport. Otherwise you can try L G Motorsports. They carry brake spindle ducts and probably have spare hose on hand.
Old 04-16-2013, 11:38 PM
morris
morris's Avatar
Not the duct just the hose itself, it is a lg setup but I don't think they can get it to me by Friday morning before I leave. I guess if I have too I can have then overnight it too me in the morning
Old 04-17-2013, 12:22 AM
Supercharged111
Supercharged111's Avatar
Can't you just ghetto rig it for a single track day? Pop holes in either side, zip tie the halves together, and duct tape the shjt out of it.
Old 04-17-2013, 12:36 AM
John Shiels
John Shiels's Avatar
Location: Buy USA products! Check the label! Employ Americans
next day doubt you will find anything locally that is any good.
Old 04-17-2013, 12:51 AM
morris
morris's Avatar
Well I'll call Anthony in the morning and see what can be done if not then improvise I suppose!
Old 04-17-2013, 09:52 AM
PushinTheLimit
PushinTheLimit's Avatar
Maybe see if LG could have it delivered to the track? I used them to replace my old worn out brake hoses and they are very good quality.
Old 04-17-2013, 10:23 AM
morris
morris's Avatar
Problem Solved Bobby is overnighting several feet too me.
Old 04-17-2013, 10:36 AM
5280Racer
5280Racer's Avatar
amazon has it.
Old 04-17-2013, 11:00 AM
morris
morris's Avatar
wow I love Amazon!
Old 04-18-2013, 05:46 PM
John Shiels
I had torque tube delivered next day from GM for hundreds. Sad part is the sent it to the wrong place and I still had to pay it.
To Need replacement brake ducting
Quick Reply: Need replacement brake ducting
