Front brake duct plates for C5 Z06?
Old 04-17-2013, 09:26 PM
WannaC5Z
WannaC5Z's Avatar
Default Front brake duct plates for C5 Z06?
Is there an aftermarket company who sells a plate which mounts to the front brake brackets which you can ziptie ducting hose to? I assume there is at least one or two but I don't know where to look. On my Cobra they replaced/mounted to where the splash guards were. You simply drilled out the rivets and then bolted in the new plates. It directed the air to the inside of the rotors.
Old 04-17-2013, 10:47 PM
Bill Dearborn
Bill Dearborn's Avatar
Received 8,910 Likes on 5,325 Posts
You can convert the C5 ducts using the DRM extensions and the LG spindle duct kit. If you want one I have an LG spindle kit left over from my C5 that I will sell for half price. One of the aluminum backing plates has a crack in it and needs to be welded but that is all that is wrong with the kit. The DRM ducts have a 4 inch hose outlet and the LG kit is sized to match them.
Bill
Old 04-17-2013, 11:18 PM
Falcon
Falcon's Avatar
When did DRM change the size of their ducts? The ones I got from them use 3-1/2" hose.
Old 04-18-2013, 07:48 PM
Bill Dearborn
You are right. I purchased mine about 9 years ago and I knew they were bigger than 3 inches but just thought 4 when I wrote the post. Just checked them now and they are 3.5 inches. Been sitting in the garage taking up space for 4 years.
Bill
Old 04-18-2013, 10:16 PM
WannaC5Z
WannaC5Z's Avatar
Bill
Can you email me a pic and price?
Old 04-18-2013, 10:39 PM
Supercharged111
Supercharged111's Avatar
I believe the LG ones are the totally enclosed ones. The style I have have a slash cut pipe welded to the plate that looks like it'd leak some.
Old 04-19-2013, 12:10 AM
79inSD
79inSD's Avatar
Here is how I did mine. Lg and DRM.
http://forums.corvetteforum.com/c5-t...t-install.html
Old 04-19-2013, 01:52 PM
WannaC5Z
WannaC5Z's Avatar
Why can't there just be a simple place to bolt the plates up w/o having to pull the hubs?!?
Old 04-19-2013, 09:29 PM
avizandum
avizandum's Avatar
http://www.lapponline.com/index.php?...roducts_id=221
Old 04-19-2013, 09:36 PM
Supercharged111
Same ones I have. I'd still go LG, it's only 3 bolts to yank the hub.
Old 04-19-2013, 09:43 PM
Falcon
Falcon's Avatar
The guy I use to repair my car after "incidents" made ducts for my car that attach to the spindle with only 1 bolt.
Very easy, very quick.
Old 04-19-2013, 09:45 PM
Supercharged111
For that matter
http://www.lapponline.com/index.php?...roducts_id=220
Old 04-19-2013, 09:59 PM
Falcon
Falcon's Avatar
Originally Posted by Supercharged111
Yep, looks like it'll work. That's an answer for the guy who wanted easy.
Old 04-19-2013, 10:16 PM
avizandum
avizandum's Avatar
Quickest and easiest is 2.5" ducting from an airplane supply website zip-tied to the Z06 outlet zip-tied to the sensor tab. And cheap.
To Front brake duct plates for C5 Z06?
Quick Reply: Front brake duct plates for C5 Z06?
