Introducing 05-13 Corvette C6/ZO6/GS/ZR1 Front Grille Mounted Brake Cooling Duct
Old 04-19-2013, 08:26 AM
0Xplosive Performance
Former Vendor
Xplosive Performance's Avatar
St. Jude Donor '13
Default Introducing 05-13 Corvette C6/ZO6/GS/ZR1 Front Grille Mounted Brake Cooling Duct
For those who need added brake cooling
XP Motorsports 05-13 Corvette C6/ZO6/ZR1 Front Grille Mounted Brake Cooling Duct System
Everything you need to install grille mounted brake cooling in your C6 Corvette. The ducts fit behind the front grille no need to loose your fog lights. The ducts mount on the inner grille support (triming of the support is required). For ease of installation removal of the front bumper is required.
Kit Includes
(2) Large Brake Duct Vents
(2) Spindle Mount Brake Hose Adapters
(2) 3" Hose Clamps
(10Ft) High Temperature 550 degree Silicon Brake Hose
(1) Horn relocation Bracket
Mounting Screws
Instructions
Quick Reply: Introducing 05-13 Corvette C6/ZO6/GS/ZR1 Front Grille Mounted Brake Cooling Duct
