Wheels & Tires Corvette Wheel & Tire Sizing Info, Staggered Fitment, Tread Compound, Tire Pressure, size option
It has happened!!!! Vorsteiner Flow Forms!!
Old 04-19-2013, 03:41 PM
thewb
Supporting Vendor
thewb's Avatar
Default It has happened!!!! Vorsteiner Flow Forms!!
Vorsteiner one-piece collection of Flow Formed aluminum concave wheels has various different fitments and finishes to match your vehicle and style. Carefully designed to optimize weight and strength, each wheel is partly machined specifically for each client according to wheel size, vehicle model and load ratings.
1-piece fitments and finishes in:
19 and 20 inch
5 Twin Spoke Design
Flowformed Aluminum 1-piece monoblock construction
Factory Tire Pressure Monitoring System (TPMS) compatible
Aftermarket big brake clearances ready to be built out of box
Designed & engineered to minimize unsprung weight for improved vehicle performance
Rigorously tested to exceed safety standards
Snap-in OE factory center cap fitment available
20 inch setup are starting at $3000 for the full set!
Quick Reply: It has happened!!!! Vorsteiner Flow Forms!!
