Anyone use Hardbar two piece rotors????
Old 04-20-2013, 12:58 AM
trapp
trapp's Avatar
Default Anyone use Hardbar two piece rotors????
Anyone use the light-weight two piece rotors by Hardbar.... Are they safe and or worth the very high cost?
Thanks!
Old 04-20-2013, 07:09 AM
John Shiels
John Shiels's Avatar
Location: Buy USA products! Check the label! Employ Americans
Thanks!
Everything is relative in regards to money for each person and performance.
Many here use them and anything hardbarUSA makes is safe and top quality. There are some other theads you can on peoples comment on the product.
Old 04-20-2013, 09:25 AM
trapp
trapp's Avatar
Thanks John, I wanted to make sure they are topnotch as far as safety...I don't mind spending the money but I just didn't want to sacrifice safety!
Tom
Old 04-20-2013, 11:25 AM
von zoom
von zoom's Avatar
Not to hijack his question, but how do they compare with Coleman which I am using now. In time, I will need to replace them, so simply trying to plan.
vz
Old 04-20-2013, 11:32 AM
yakisoba
yakisoba's Avatar
It's more of a philosophy thing, most likely. Either you try to make your rotors last as long as possible, which means two piece with cryotreated rings and very carefully chosen pads, or you treat them as a wear item and replace often. If I were in the former group, I would not hesitate to get Gary's rotors.
Old 04-20-2013, 02:11 PM
db2xpert
db2xpert's Avatar
Been running Hardbar for 3 yrs on the C6 Z. No issues. Good stuff.
I think those are Coleman rotors on the hats...??
Been running Coleman on the AP hats on the C5Z for 12 yrs.
Old 04-20-2013, 11:26 PM
trapp
trapp's Avatar
Colemans are 6.5 lbs lighter then stock
Hardbars are 11 lbs lighter then stock........
Hardbars are about twice the cost..
Old 04-22-2013, 08:03 PM
Bedouin
Bedouin's Avatar
I'm running the Finspeed 2-pc rotors w. stock calipers/pads & am 100% satisfied. Each front rotor weighs 10 lbs less than stock, each rear weighs @ 6 lbs less than stock..the rear's are ebrake compatible.
Top pic is the rear, bottom pic is front;
Old 04-22-2013, 10:59 PM
trapp
trapp's Avatar
I wonder if the rotors could hold up to track pads such as DTC-70 or XP-20 etc...
Old 04-22-2013, 11:35 PM
Supercharged111
Supercharged111's Avatar
I thought that was the whole point of a 2 pc rotor. . .
Old 04-23-2013, 01:04 PM
trapp
trapp's Avatar
Not really...........some two peice rotors are made for reduced weight but are not recommended for track use do to lack of durablity and safety issues...
To Anyone use Hardbar two piece rotors????
Quick Reply: Anyone use Hardbar two piece rotors????
