Distorted Vision with Full Face Visor
Old 04-20-2013, 11:07 PM
Han Solo
Han Solo's Avatar
Default Distorted Vision with Full Face Visor
I recently purchased my first full face helmet and the visor causes a distorted view. Is this common with full face shields or just because I bought the inexpensive Zamp helmet?
It isn't that noticeable looking out over a distance but i was wearing it today while blowing off the back patio and it made the concrete look wavy when I looked down. So far I have just run with the visor up since I got it but that kind of defeats part of the reason for having a full face helmet to begin with.
Old 04-20-2013, 11:44 PM
sperkins
sperkins's Avatar
That's not normal in my experience.
Old 04-21-2013, 02:12 AM
harrydirty
harrydirty's Avatar
Definitely not normal............most visors can be replaced, so you should look into possibility of replacing shield with another one. You can research to see if generic replacement shields are available for your helmet, or if shields from a major manufacturer (Bell, Arai, Shoei, etc) will fit.
Old 04-21-2013, 09:31 AM
BEZ06
Support Corvetteforum!
BEZ06's Avatar
I have 2 Zamp helmets - SA2005 and SA2010.
Both are very nice helmets with absolutely no distortion when looking through the visor. I've had the SA2005 for 7 years now with original visor and it's still perfectly clear.
I just went out to the garage and tried them both - perfectly clear at all viewing angles.
I wear no-line bifocals, and when I looked down at the floor through the bottom of my lenses it was fuzzy because the bottom part of the lens is focused for close up viewing distance. When I looked at an old piece of newspaper it was perfectly clear at reading distance.
I got in the car and looked at the instrument panel and the wall in the garage and moved my head around, and at all angles the and distances the visor doesn't distort at all.
So....I think you may have a defective visor!!
Bob
Old 04-21-2013, 02:33 PM
jaa1992
jaa1992's Avatar
Location: Life is just one big track event. Everything before and after is prep and warm-up and cool-down laps GA
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude Donor '12
Did you take the protective film off the visor??
I've heard lots of "distortrd" vision stories and most of them are because the protective film was still on the visor
Old 04-21-2013, 03:28 PM
NVR2L8
NVR2L8's Avatar
I made the same mistake several years ago.
Old 04-21-2013, 04:09 PM
rfn026
rfn026's Avatar
I've got a huge helmet story in the May/June Vintage Motorsports magazine. One very important thing you have to keep in mind is that "All of the value priced helmets pass the same certification process as the expensive ones." You'll never know if the expensive helmets provide enhanced safety unless you do your own comprehensive testing."
Barnes and Noble no longer carries the magazine but you can get it for free here.
Richard Newton
Facebook
Old 04-21-2013, 09:11 PM
NASCAR314
NASCAR314's Avatar
Wow, you must live in a bad part of the Galaxy to need a full face helmet just to go out on the patio!
Old 04-21-2013, 11:29 PM
Han Solo
Han Solo's Avatar
Actually it was cool yesterday morning and I decided to wear it while I mowed. Turned out to be a great idea for protection from the wind, dust, and low limbs. I got finished mowing and just left it on to do some blowing.
I will check to see if it has a protective coating I missed. If not I will contact Zamp to see what they have to say about it.
Old 04-21-2013, 11:34 PM
froggy47
froggy47's Avatar
Have a friend try it on & ck for distortion
I only buy cheap helmets & never had a bad shield.
Old 04-22-2013, 07:58 AM
rbl
rbl's Avatar
Put a couple of cell phone antennas on it next time and you will be at home .... Galaxy Traveler
Old 04-22-2013, 01:25 PM
brkntrxn
brkntrxn's Avatar
Were you wearing polarized sunglasses under the shield by chance? A couple of years ago,I made the mistake of wearing my polarized Oakley's under my Simpson amber shield. I came out of the pits at Roebling, started through Turn 1, and almost puked by T2. Major double vision and distortion. Immediately made me feel like I was drunk and I do not get motion sickness very easily.
To Distorted Vision with Full Face Visor
Quick Reply: Distorted Vision with Full Face Visor
