Introducing PLANTED seat mounting brackets
Former Vendor
St. Jude Donor '13
Planted Seat Bracket
The Planted Seat Bracket is made with 3/16" thick steel for superior strength. It is built to accept sliders from most major seat manufacturers like Bride, Cobra, Corbeau, Momo, OMP, Racetech, Recaro, Sparco, Status & more. Extra material is provided for direct seat or side mount applications where eliminating sliders is preferred. They are finished with a black powder coat
Chevrolet Corvette C5/C6/Z06 (1997+) - Driver
http://www.xplosiveperformance.com/C...er_p_3305.html#
Chevrolet Corvette C5/C6/Z06 (1997+) - Passenger
http://www.xplosiveperformance.com/C...er_p_3306.html#
Former Vendor
St. Jude Donor '13
Former Vendor
St. Jude Donor '13
Former Vendor
St. Jude Donor '13
Former Vendor
St. Jude Donor '13
[QUOTE=larryfs;1583874371]Are those lowering brackets ?[/QU
OTE]
NO The Planted Seat Bracket is built to install a RACE SEAT into your car an built to accept sliders from most major RACE seat manufacturers like Bride, Cobra, Corbeau, Momo, OMP, Racetech, Recaro, Sparco, Status & more. Extra material is provided for direct seat or side mount applications where eliminating sliders is preferred. They are designed to bolt to the factory mounting location so no need to drill any holes in your car. They are finished with a black powder coat
OTE]
Why do seat mounting brackets always taller in the front? Since most people are trying to get the seat as low as possible it seems like it would be better to keep them right on the floor.
I agree. With a helmet on, we are already losing 2" of head room. And any person 6'1" at taller, head room gets tight with a helmet. Especially with a upright seating position.
In most cases, if you sight straight upward, you would be miserably uncomfortable AND have less headroom. Tilting it back gives you more space since the front is just raising your knees, not your head. Also, Pythagorean theorum applies......more tilt equals more headroom.
That being said, if you are really tall, you need to be mounted directly to the floor, OR use an aluminum seat to get really low.
I wonder if you can just bolt the stock seat directly to the bracket and eliminate the slider to gain height. Of course this assumes the pedal distance works. I have C6RS seats but they are built from stock seats.
Former Vendor
St. Jude Donor '13
Former Vendor
St. Jude Donor '13
Former Vendor
St. Jude Donor '13
Former Vendor
St. Jude Donor '13
http://www.xplosiveperformance.com/H...in_p_3545.html
we also have a seperate sub belt bracket that mounts at the rear of the seat and is $165.00
