Help in Nashville, TN
Old 05-10-2013, 02:49 PM
Painrace
Support Corvetteforum!
Painrace's Avatar
Default Help in Nashville, TN
Hey guys, I recently moved to the Nashville, TN area (Mt. Juliet) and my wife is building a now home. So, I don't have a place to make some Aeroquip modification to my car. Is there a good shop in the area to do this for me?
It is not a big job. I am going to be testing a new product for ARE and I need to get it installed.
Thanks, in advance, for your help.
Jim
Old 05-10-2013, 04:58 PM
PushinTheLimit
PushinTheLimit's Avatar
Jerry Onks could probably help you... he has a shop in Smyrna,TN. VetteSport is the name.
Old 05-10-2013, 08:51 PM
NVR2L8
NVR2L8's Avatar
Jerry is a great guy, and if he can't do the work you need, I am sure that he can point you in the right direction.
Old 05-12-2013, 09:40 PM
Painrace
Painrace's Avatar
Thanks guys. I emailed Jerry.
Jim
Old 05-22-2013, 12:06 PM
yow
yow's Avatar
Agreed with the above comments.
Old 05-22-2013, 09:23 PM
Painrace
Painrace's Avatar
I met Jerry and Tim today. Very nice guys. They are installing an experimental part for me from Gary at ARE that will reduce the air in the oil going back to the dry sump tank. We think it will lower oil temps 10-15 degrees and there will be less air in the oil lubricating the engine. We plan to do an A/B test at VIR at the NCM event.
Jim
To Help in Nashville, TN
Quick Reply: Help in Nashville, TN
