Pfadt Camber Kit Questions
Old 05-12-2013, 06:02 PM
Last C5
Last C5's Avatar
Default Pfadt Camber Kit Questions
On a C5Z, slightly lowered and using Ti A arms,
Which camber blocks do you use to get close to minus 3 up front and minus 2 in the rear?
I understand that they are marked with notches or something?
Old 05-12-2013, 06:08 PM
JDIllon
JDIllon's Avatar
Are these for a C5? You can go on there website and get all of the instructions for installing them! The kits are different for different cars. For a C6-Z06 you use the ones with a Z on them in front and whether the Z goes in or out determines the amount of camber. JD
Old 05-12-2013, 06:16 PM
Last C5
Last C5's Avatar
Sorry, it's for the C5 Z (I edited my original post). I thought I had looked on the Pfadt website and couldn't find any directions, but I'll look again. Thanks.
Now that I've read them, those directions seem to leave a lot to trial and error. I was trying to minimize that with someone's experience.
Old 05-12-2013, 07:43 PM
J.R.
J.R.'s Avatar
Every car is different due to variations in manufacturer build.
For the front use the 6 and you can fine tune with shims.
For the rear it is trial and error and one side may be different than the other but most likely you will need between a 4 and a 6 to get 2 deg. negative.
Old 05-13-2013, 01:37 PM
Last C5
Last C5's Avatar
Thanks JR, that gives me a place to start.
Old 05-13-2013, 02:06 PM
JDIllon
JDIllon's Avatar
The nice thing about the kit, is if you take the time to do it right! It should stay there and not change. JD
Old 05-13-2013, 02:07 PM
froggy47
froggy47's Avatar
What he said.
Old 05-13-2013, 03:11 PM
hklvette
hklvette's Avatar
Just as a data point:
Mine coupe could get -3* camber, 6* caster up front with no shims. On the rear, I used 6 on the driver's side and 5 on the pass. side and got -1.6/-1.7, respectively.
My 2cents
Old 05-13-2013, 06:24 PM
Last C5
Last C5's Avatar
Originally Posted by froggy47
What he said.
Always good to hear from you Froggy. You've upgraded your A arms beyond the T1 arms now, right?
My 2cents
Appreciate the input.
Old 05-13-2013, 07:44 PM
froggy47
froggy47's Avatar
Running Pfadt poly now, great setup for a street/track machine.
To Pfadt Camber Kit Questions
Quick Reply: Pfadt Camber Kit Questions
