Track day Laguna Seca, chasing a Lotus 211
Old 05-21-2013, 07:03 PM
Gary(SF)
Gary(SF)'s Avatar
Default Track day Laguna Seca, chasing a Lotus 211
For those of you not familiar, the Lotus 211 is a sports racer based on the Elise, 250 hp/1500 lbs, on slicks of course. It was great fun to chase him around. My C6 Z06 has StopTechs and RA-1s, otherwise stock.
Old 05-21-2013, 09:07 PM
2002rich
2002rich's Avatar
Great driving Gary. That Lotus 211 is nimble and the HP to weight ratio is fantastic. Looks like you got hung up behind the 510.
Old 05-21-2013, 11:55 PM
FruiTay
FruiTay's Avatar
Awesome! I've always loved that track but unlike you sir, I have only raced it on video games. Looks like you did a hell of a job.I'm curious of you clocked any lap times?
Sweet ride, happy to seen you using it. Thanks for the video!
Old 05-22-2013, 08:25 AM
Gary(SF)
Gary(SF)'s Avatar
Best lap that day was a 1:40.5, about a second slower than my best at Laguna. Warm day and a little greasy.
Old 05-22-2013, 08:32 AM
CHJ In Virginia
CHJ In Virginia's Avatar
Nice video - thanks for posting ! I have always wanted to drive that track, but unfortunatly, it's 3000 miles away. A bit far to tow.
Old 05-22-2013, 08:35 AM
Gary(SF)
Gary(SF)'s Avatar
We had some participants Monday that came a long way...a Z06 from British Columbia, a C6 from Nevada, and several other cars from SoCal. One of the classic tracks in America, that's for sure.
Old 05-23-2013, 12:02 AM
5280Racer
5280Racer's Avatar
Awesome driving!!
Old 05-23-2013, 10:35 AM
Rookieracer
Support Corvetteforum!
Rookieracer's Avatar
Watching the video, it appeared the car was suffering from understeer in just about every corner?
Old 05-23-2013, 10:40 AM
Gary(SF)
Gary(SF)'s Avatar
The only corner I was having a little trouble with understeer was T2, and it is worse when the track is greasy for some reason. Next set of tires I think I will try larger fronts, I am running 275 front/335 rear now, probably go to 285.
Old 05-23-2013, 10:47 AM
Rookieracer
Listening to the tires and watching your hands on the wheel is why I asked the question. I kept rooting for you to reel him in and make the pass.
I really enjoyed the video! It's alway fun to have a rabbit to chase. Thanks for posting.
I wonder if a little softer front sway bar or stiffer rear bar might help the balance? Assuming front tire pressures weren't too high.....
Old 05-23-2013, 11:00 AM
Gary(SF)
Gary(SF)'s Avatar
RA-1s tend to be a bit noisy at the limit anyway, not as quiet as a Hoosier or similar, and they don't have the turn-in bite of a softer tire either. If it had been a race situation I am confident I could have made a pass up into T6 or T7, I was actually feathering the throttle in both those places to avoid running up his backside, but it would have been an aggressive maneuver and perhaps a bit inappropriate for a DE.
Tire pressures were 35F/36R hot. The RA-1 is a great DE tire, pretty cheap and impervious to heat cycles. I run them all year long, drive them to and from the track, and typically get 12 - 13 track days and 5k street miles, so they are very cost effective. All that said, they are far from the quickest tire out there.
Thanks for your perceptive comments!
Old 05-23-2013, 11:03 AM
Bill32
Bill32's Avatar
Nice driving and lap times.
Corner entry in 2 may be just a tad tight and that usually causes a push for me.
Old 05-23-2013, 11:09 AM
Gary(SF)
Gary(SF)'s Avatar
I've tried different lines in T2 and it seems to me to be kind of a tossup...my current technique is to brake as late as possible and make a bee-line for the first apex, keep a tight line to the second apex, and just avoid trying too hard in what is IMO a throw-away corner. YMMV...I will say most C6 Z06 guys use the "wider entry, single late apex" technique, but following them I don't think it is really any faster. Some guys use 2nd gear in T2 also, but I have trouble getting any more power to the ground than when I'm in 3rd gear, so I just stick with 3rd.
Old 05-23-2013, 11:24 AM
Bill32
Bill32's Avatar
Yea, it's a tough turn Gary. I pushed a lot when I first raced there though in a way different car. Moving my line out 2-3 feet off the first apex helped (larger radius, less scrub).Not many corners on a track can be run fast with 2 different lines but this one can.
I think you're definitely right about 3rd. I would think that you'd have to slow down too much to use second effectively.
I try and get a tach reading right at full throttle application in corners like this.
Old 05-23-2013, 11:55 AM
Gary(SF)
Gary(SF)'s Avatar
If nothing else it sure provides lots of fodder for bench racing!
Old 05-23-2013, 12:09 PM
Bill32
Bill32's Avatar
Oh, yea.
Old 05-23-2013, 02:04 PM
shakedown067
shakedown067's Avatar
St. Jude Donor '12-'13
Nice video!
To Track day Laguna Seca, chasing a Lotus 211
Old 05-23-2013, 04:41 PM
Dr.Ron
Dr.Ron's Avatar
Location: 2007 Nat'l Corvette Challenge 11.50 index Champ. New Jersey
Nice driving!
That guy in the Viper was scary for much of the time. I was waiting for him to go off again!
Seemed to have settled down some towards the end though.
Awesome video!
Ron
Old 05-24-2013, 01:50 PM
jlutherva
jlutherva's Avatar
With Hoosier R6's, I like 315/30R18 front and 335 or 345/30R18 rear. My C6Z has poly bushings & DRM Bilstein shock and handles neutral with those sizes.
Jim
Old 05-24-2013, 01:52 PM
Gary(SF)
Gary(SF)'s Avatar
Jim
Yeah I'm clearly undersized in the front.
Quick Reply: Track day Laguna Seca, chasing a Lotus 211
