Brake Questions
Brake Questions
I have a 2011 Grand Sport. Starting to autocross maybe 8-10 times a year. (Newbie) What would be a good recommendation on brake pads and rotors. Some guys have told me to get away from the drilled brakes.????
Also I wanna go to a 1 piece pad. Any suggestions would be helpful. Thanks Shannon
I just did a column on brake pads for Vintage Motorsport magazine. You need to talk to the brake pad companies but you also need to be prepared to answer some questions. They need to know about your car (and you) before they can make a recommendation.
Drilled brake rotors are a cosmetic item. They crack if you use them on the track. Ask the pad companies if they have any suggestions regarding brake rotors. I also did a column on brake rotors last year.
Richard Newton
Facebook
Richard Newton
Drilled rotors are for looks. Not as strong as slotted or blank rotors.
Supporting Vendor
St. Jude Donor '11,'13
What tires will you be using?
Do you mind noise and dust?
Are you leaving this pad on as a dual purpose pad street and Autox?
Do you ever plan to do a track day?
__________________
Adam Adelstein
Amp’D Autosport.com
Internet's largest retailer of Carbotech Performance Brake Pads.
PH:216-780-8825.
Email: sales@ampdautosport.com
Web Site & Direct ordering http://ampdautosport.com/
All major CC and Pay Pal accepted.
Check out Promo code:z28
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
Also consider Cobalt Pads, they were one of the first to make a one piece pad for the stock C6-Z06 caliper. They make a great product. And there is no bedding. JD
Tolero Apto Victum
OP: Here are some threads that you may like: http://forums.corvetteforum.com/auto...ad-wear-2.html post# 25 & http://forums.corvetteforum.com/auto...necessary.html & http://forums.corvetteforum.com/auto...t3-rotors.html
You can buy air ducts spindles that connect the stock brake air ducts directly to your rotor/calipers.......to keep brake fluid from boiling..
You can buy titanium shims to keep brake fluid from boiling..
You can buy different brake pistons to keep the brake fluid from boiling..
You can use Castrol SRF brake fluid that is very resistant to boiling.
Tom
You can use the stock rotors....I used them for a few years and they worked good....
I your not planning on switching them out back and forth then just use your stock pads until they wear out...........You can go with Carbotechs advice for upgrading once you gain experience...
