6 Point Belts
Old 06-14-2013, 03:03 PM
Screamin Z
Screamin Z's Avatar
Default 6 Point Belts
What are you guys using? In the market for some better belts.
Would like pull up lap belts that are usable while in the seat. Also shoulder belts that are Hans friendly. (2")
Old 06-14-2013, 03:35 PM
Scooter70
Scooter70's Avatar
TeamTech Jet Pilot
Old 06-14-2013, 03:46 PM
MarkDFW
MarkDFW's Avatar
Schroth profi II
Old 06-14-2013, 03:48 PM
JeremyGSU
JeremyGSU's Avatar
I have G-Force
Old 06-14-2013, 03:53 PM
Falcon
Falcon's Avatar
I finally went with G-Force pull downs because they are FIA good for 5 years vs the pull ups which were only good for 3 years.
Once the lap belt lengths are set, I've never had to adjust them again, so the pull downs work well for me. And Ii gained 2 years out of it.
Old 06-14-2013, 04:53 PM
dvandentop
dvandentop's Avatar
g force pull downs are what i have good pricing too
Old 06-14-2013, 05:05 PM
CHJ In Virginia
CHJ In Virginia's Avatar
I use the Crow cam lock 6 point bests. Once your lap belts are set, no other adjustment is needed. Shoulder belts offer a easy adjust pull down. Camlock is the easiest attach and quickest release I have found.
Old 06-14-2013, 05:45 PM
spdislife
spdislife's Avatar
TeamTech Rampac
Old 06-14-2013, 05:46 PM
JDIllon
JDIllon's Avatar
I have been running the Schroth for the last year because I got a set at a good deal and they are lighter and nicer than the G-Force. But I had good luck with the G-Force before that. I have both in the car. G-Force for passenger and Schroth for the Driver. You can try them next week at VIR. JD
Old 06-14-2013, 09:58 PM
trackboss
trackboss's Avatar
I swear by teamtech jet pilot, but I've had friend try it and he hates it. One nice feature is that it requires only two lower points for mounting because each pair of side lower belts "Y" together to a single anchor per side. Makes installation really easy.
Old 06-15-2013, 12:16 AM
skxf430
skxf430's Avatar
Schroth Profi are really nice.
Old 06-15-2013, 12:19 AM
fatbillybob
fatbillybob's Avatar
Brand is not as important as 6pt style, belt material, and mounting
A poly belt is certified longer than nylon
as for 6pt styles:
hybrid 4 shoulder straps imo best
hybrid
formula
T
V imo worst
as for mountings:
proper anchoring of subs and proper angles
subs anchors to sheet metal floors and proper angles
anchors to rear seat mounts bad angles using seat hole to compensate
sub anchors to rear seat mount parachute style
Old 06-15-2013, 01:59 AM
Joy of 6
Joy of 6's Avatar
This is what I swear by. One reason is that loosening the shoulder belts is easy and doesn't take a strong arm to loosen them, just a tug. As above once the sub and laps are set then only the shoulders need adjusting. Just another tug after a couple laps
Old 06-15-2013, 08:02 AM
AU N EGL
AU N EGL's Avatar
Twin and zip ties.
Old 06-15-2013, 11:56 AM
RedLS1GTO
RedLS1GTO's Avatar
Pretty good advice in that reply.
I've used quite a few brands in various applications over the years. All have served me well.
On a personal note... I have only been in 1 car with the Team Tech Jet Pilot harnesses and couldn't stand them.
Old 06-15-2013, 06:01 PM
mcar00
mcar00's Avatar
Schroth here. Work well.
BTW. You guys going to have that E85 drinking monster at VIR for the NCM event? If so, see ya there.
Old 06-16-2013, 07:55 PM
von zoom
von zoom's Avatar
I use 6 point G Force also. Like them a lot. I will be at VIR for the NCM Event. See you there.
vz
To 6 Point Belts
Old 06-16-2013, 08:02 PM
Vettechris996
Vettechris996's Avatar
Schroth Profi II here.
Old 06-16-2013, 11:07 PM
Dre01SS
Dre01SS's Avatar
Sparco 6pt mounted to Hardbar Lap Belt bar and Sharkbar.
Old 06-17-2013, 09:35 AM
sebdavid
sebdavid's Avatar
Schroth Enduro used here, ideal for changing drivers often, which is a factor for me.
Quick Reply: 6 Point Belts
