Button on the shifter to "blip" the throttle?
Old 06-18-2013, 12:48 PM
moespeeds
moespeeds's Avatar
Default Button on the shifter to "blip" the throttle?
A good friend of mine just purchased an 08 Z06, mostly to do track days, with the occasional cruise around town. He has nerve damage to his right foot from a motorcycle accident, and while I was at the track with him this past weekend he was having a hell of a time heel toe shifting. He has no feeling in his right foot. I saw the thread with the C5R race car with the button to blip the throttle, but can this be done on a stock C6Z?
Old 06-18-2013, 02:18 PM
ErnieN85
ErnieN85's Avatar
yes for about $50,000 ..............it's the sequential shift trans they use
Old 06-18-2013, 02:21 PM
RDnomorecobra
RDnomorecobra's Avatar
how does he brake effectively?
Old 06-18-2013, 07:33 PM
RedLS1GTO
RedLS1GTO's Avatar
I believe he is talking about the button being discussed on this car:
http://forums.corvetteforum.com/auto...-race-car.html
Not a sequential shift gearbox.
Old 06-18-2013, 07:44 PM
moespeeds
moespeeds's Avatar
With the throttle by wire there is no way to make a circuit to blip it? No I'm not referring to a sequential gearbox.
Old 06-18-2013, 07:55 PM
ErnieN85
ErnieN85's Avatar
could be thats real nice
Old 06-18-2013, 08:06 PM
sleeperstyle
sleeperstyle's Avatar
i found a thread from 06 talking about doing it on a c5, it ends with no more info.. best i could find..
http://forums.corvetteforum.com/c5-t...ttle-blip.html
the car mentioned in the thread above (racecar) has a different ecu- motec i believe.
it is a cool idea and i am sure it can be done, but as i read from that old thread it can create an unsafe condition with the electronic throttle
good luck
Old 06-18-2013, 10:23 PM
RedLS1GTO
RedLS1GTO's Avatar
I have no clue. I was just pointing out that the "C5R" in question with the button wasn't this:
Which would indeed have a mucho dollar sequential gearbox as Ernie said.
Old 06-19-2013, 08:11 PM
FlamingZ06
FlamingZ06's Avatar
Call david at Speedsouth 205-621-6969. They have done this on both h pattern and sequential shift cars. The owner had one on his C6 that blipped automatically with no need for a button. It could be turned off when not on track.
Old 06-19-2013, 09:34 PM
froggy47
froggy47's Avatar
6:00 min into the video if anyone else goes searching for it.
I forget which car, but there is one now that blips as you move the shifter, no button.
Old 06-19-2013, 11:00 PM
yooper
Support Corvetteforum!
yooper's Avatar
Old 06-20-2013, 02:13 PM
mindvexed
mindvexed's Avatar
I found a wiring schematic for the throttle actuator control module for 97-2005 vettes, and it looks like you could intercept the accelerator pedal signals (wires 417 & 427) and apply a signal that simulates higher throttle position percentage.
http://chevythunder.com/Engine%20sen...ule,%20TPS.gif
I'm thinking you could use a blip button signal to actuate a micro-relay with the pedal signal on the normally closed side and a constant voltage on the normally open side.
You'd have to determine what voltage relates to what throttle position for both of the accelerator pedal signals, then apply a voltage that equates to whatever throttle position you want for your blip.
Old 06-20-2013, 02:52 PM
RX7 KLR
RX7 KLR's Avatar
The 370Z does it for you.
Old 06-23-2013, 05:55 PM
TriplBlk
TriplBlk's Avatar
exactly
Old 06-25-2013, 08:28 PM
VGLNTE1
VGLNTE1's Avatar
St. Jude Donor '14-'15
Subscribed
Old 06-26-2013, 10:36 AM
moespeeds
moespeeds's Avatar
Just an FYI, speedsouth is in the process of building a plug and play kit for this. It should be just a few weeks from hitting the shelves. I'll keep you guys posted.
Old 06-26-2013, 10:40 AM
crimlwC6
crimlwC6's Avatar
To Button on the shifter to "blip" the throttle?
Old 06-26-2013, 02:25 PM
nassaubluecoupe
nassaubluecoupe's Avatar
The C7 does this, from the factory, so I'm sure there is a way to do it for the C6.
Old 06-26-2013, 05:28 PM
AU N EGL
AU N EGL's Avatar
Buy a C7 with Z51 package, 7 speed manual
has an automatic rev match for shifting up or down.
Works good too.
Old 06-27-2013, 12:03 PM
sgrinavi
sgrinavi's Avatar
Works good too.
Very helpful, thanks
Quick Reply: Button on the shifter to "blip" the throttle?
