What is the GM spec for oil pressure @ temp?
2010 A6 GS, LS3, M1 5w 30.
I've read about the 10psi/1k rpm guideline that is generally used. Also heard spec is lower for higher temps (presumably above 212F) but did not find the data for any temp.
At the oil temps I run (270 to 280-F) I use Mobil 1 0W40 to get higher oil pressure at high load & RPM. 2006 M6 LS2
Lots of videos with oil temp, pressure, and RPM logged here:
