David Farmer's website
Old 06-25-2013, 09:50 AM
GOTHAM VETTE
GOTHAM VETTE's Avatar
Default David Farmer's website
Am I the only on that gets pictures of a field, and trees and a bunch of unrelated links??
I'm trying to find the Accusump install link to confirm what size fitting I need for the front driver's side plug.....
Old 06-25-2013, 09:52 AM
sleeperstyle
sleeperstyle's Avatar
i always got the same, then found the info elsewhere. good luck
Old 06-25-2013, 02:25 PM
el es tu
el es tu's Avatar
Default Documents from David Farmer's site
http://forums.corvetteforum.com/auto...id-farmer.html
accusump link is further down this page
EDIT:
here's the link https://dl.dropboxusercontent.com/u/...6/accusump.pdf
Old 06-25-2013, 03:48 PM
Last C5
Last C5's Avatar
The galley threads are M16 X 1.5 and the Parker fitting you need is
#10M16C80MXSS For the -10 AN 90 deg stainless adapter
or
#8M16C80MXSS For the -8 AN 90 deg stainless adapter
Old 06-25-2013, 05:19 PM
shakedown067
shakedown067's Avatar
St. Jude Donor '12-'13
I think he ditched the website and moved on to a facebook fan page. It's free.
Old 06-26-2013, 03:33 PM
Z06Tracker
Z06Tracker's Avatar
That is correct.
To David Farmer's website
Quick Reply: David Farmer's website
