Wheels & Tires Corvette Wheel & Tire Sizing Info, Staggered Fitment, Tread Compound, Tire Pressure, size option
TPMS Placement Issue with Aftermarket Wheels
Old 07-01-2013, 02:02 PM
PaulV20
PaulV20's Avatar
Default TPMS Placement Issue with Aftermarket Wheels
TPM Install on CRAW - Hawk Wheels,
The TPM on the Hawk's are installed at the rear area of the wheel through and additional hole in the rim. When I installed the OEM TPM the valve stem sticks-out facing the suspension(Fronts only). When the wheel is at full right turn the stem almost touches the tie-rod end. So, I am looking for another style TPM that has a removable stem which can be exchanged for a Valveless Adapter Kit designed for this type of application.
Any feedback will be appreciated,
Thanks,
Paul
Old 07-01-2013, 11:05 PM
geewez
geewez's Avatar
Look on the iForged web site under wheel accessories. They sell an adapter bracket which mounts the TPMS sensor using the valve stem to hold it in place inside wheel. That's where I have mine mounted. Another way of mounting the sensor is to steel band it to the inside of the wheel.
Old 07-02-2013, 10:45 AM
PaulV20
PaulV20's Avatar
Thanks for the input, this is jut what I was looking for! When looking at the website it's hard to see how the stem is secured to the adapter? Do you use the same nut that comes with the TPM?
Thanks again,
Paul
Old 07-03-2013, 02:38 AM
geewez
geewez's Avatar
Yes.
To TPMS Placement Issue with Aftermarket Wheels
Quick Reply: TPMS Placement Issue with Aftermarket Wheels
