C5 Panel Bonding
Old 07-06-2013, 10:55 AM
matchstick
matchstick's Avatar
Default C5 Panel Bonding
What kind of adhesive works best to put the inner fenders back on the front of a C5?
Old 07-06-2013, 11:42 AM
Falcon
Falcon's Avatar
Old 07-06-2013, 12:21 PM
sperkins
sperkins's Avatar
Originally Posted by Falcon
The lighter fluid is just to the left of those dollar bills in the background right?
Old 07-06-2013, 12:51 PM
Falcon
Falcon's Avatar
Yep!
Old 07-06-2013, 01:00 PM
drivinhard
Support Corvetteforum!
drivinhard's Avatar
Jody owns stock in that company
Actually if only 10% of the inner panel is still there, Jody will rivet in the rest of it
Old 07-06-2013, 01:03 PM
Falcon
Falcon's Avatar
We ran out of material to rivet, so now I've got complete unmolested inner fenders.
I never knew what they looked like before.
Old 07-07-2013, 12:41 AM
crease-guard
crease-guard's Avatar
The other stuff that's also used is the 3M 08115. Probably the same as the SEM. I used it to bond some aluminum sheet to the under side of my spliter/undertray and rockers. Stuff works great, really strong.
I got the first couple of tubes online but ran out and found the local O'Rielys auto parts kept it in stock. Was a bit more expensive, but I was able to buy it on the spot and finish the job before my track day the next day.
If you use either of those, you're going to need the dispenser gun.
Old 07-08-2013, 09:54 AM
matchstick
matchstick's Avatar
Thanks guys. I ordered some today.
To C5 Panel Bonding
Quick Reply: C5 Panel Bonding
