Trailer and tie down help
I am finally ditching the tire trailer I pull behind the vette and stepping into an 18' dovetail open deck trailer. I have searched everywhere on here and come to the conclusion that I want to use the T-hook method to tie down, and I will use flat snap hooks to secure the T-hooks.
My issue is how I connect the other end to the trailer. I don't have D rings, so I have to rely on the stake pockets. Is it safe to assume I don't want to use the snap hooks on those stake pockets? I can buy flat hook components separately and attach them to the ratchets if necessary, but do I need to? Any help is much appreciated. I haven't ever towed a car before, so pretty much everything I know is from this forum and various other reading / watching videos.
Cheers!
Cheers!
Ripped the straps...but the d-rings were all still in place.
You just need grade 8 bolts...get it welded afterwards when you have the time to do so.
No issue with grade 8 bolts and d rings unless you bolt to some really bad material....
Just buya set of d rings and some good hardware (some d rings include the hardware) and you would be good.
Or, swing by any trailer shop, and they can tack them on relatively easilily
you don't want to buy one set of straps for now and another later. so either get the D rings welded on now, or bolt them on but in the same basic position that you will weld them later. you will likely want twisted end snap hooks on the fixed, D ring side, and like you stated, flat snap hooks on the car side with T hooks. I love that set up, each strap perfectly flat, no twist and no rubbing against each other. car is solid as a rock on my trailer.
I'm going D-rings, twisted T hooks, and twisted snap hooks. Only problem I am running into right now is that I can't find long enough straps anywhere online that has the T hooks too. I'm paying for second day air to get it here before Friday, so I don't want to split the shipment. Anyone have a line on straps and T hooks? Everywhere that has them sells the straps in 8 foot options. I'm thinking that by the time I cross the straps and run them to the front / rear, I'm going to need at least 15 foot straps. Thoughts?
I use 8' straps on my 18' trailer with no issues. However, that also depends on your attachment points. My points are about 2' in on the front and back, if you are using stake puckers for now, length may be an issue, but the solution is not to cross strap, as there is little proven need for cross strapping. Use your t hooks and just anchor to the closest point and you won't have any issues.
my attachment points are at the end of my 18' runners so I use 10' straps. Mac Custom tie downs. Get the t-hooks separate from Northern tool. The ones MAc's sells have a chain link in them which twist them another 90 degrees.
Well, I managed to pick up mac 10' straps and T hooks from summit for $175. Hopefully everything works out. Now I just have to modify the deck enough to open my doors over the fender.
Bolt them down...good to go.
Most people just put sections of 2x12 under the tires to raise the car enough to clear the fenders...usually 1 (sometimes 2) high. Bevel the edges at 45 deg...make the second layer shorter in length than the bottom layer. Works great...cheap temp solution.
The best part is it isn't "permanent"...if you need to use the trailer for anything else it is easy to get it back to a standard setup.
