Switches at the top and bottom of the clutch pedal, what do they do?
Old 08-11-2013, 09:52 PM
moespeeds
moespeeds's Avatar
Default Switches at the top and bottom of the clutch pedal, what do they do?
I'm making up a pedal stop for my clutch. At the bottom of the clutch travel is a stop with a switch in it and a plug. Same at the top of travel. What are these switches, and does the car need them to start/run?
Old 08-12-2013, 12:07 AM
Screamin Z
Screamin Z's Avatar
Yes. The lower switch when pressed tells the computer the car is in neutral and will allow the car to crank. The upper switch is a cruise kill switch. If you have cruise engaged and try to shift gears, It will detect the clutch pedal has been pushed and it will disengage the cruise feature. The lower switch has to be utilized. The top one doesn't. Unless, you want cruise control.
Old 08-12-2013, 12:09 AM
drivinhard
Support Corvetteforum!
drivinhard's Avatar
If you have a cage now, dump the clutch start switch. While in the paddock, you'll want to be able to reach in and just fire it up without climbing in and pressing the clutch in every time you want to warm it up or check on something under the hood.
Just have to remember to check to make sure it's in neutral
Old 08-12-2013, 12:26 AM
moespeeds
moespeeds's Avatar
So I'll just jump the clutch switch? Or is it normally closed? Besides the fact that I don't need it, I need to mount a pedal stop there.
Old 08-12-2013, 12:31 AM
sperkins
sperkins's Avatar
Yep.
To Switches at the top and bottom of the clutch pedal, what do they do?
Quick Reply: Switches at the top and bottom of the clutch pedal, what do they do?
