ZR1 rotors
Old 08-15-2013, 08:26 PM
JohnAlley
JohnAlley's Avatar
Default ZR1 rotors
Just got a 2011 Z06 Carbon Edition which has the ZR1 ceramic rotors. Any thing special I need to do with the rotors if I want to autocross the car?
Old 08-15-2013, 09:35 PM
SouthernSon
Support Corvetteforum!
SouthernSon's Avatar
Location: Deal's Gap 2004 NCM Motorsports track supporter
Received 1,101 Likes on 715 Posts
You make me sick.
(Probably 7 oz.'s of iron filings floating around in the engine oil.......)
Old 08-15-2013, 11:36 PM
phipp85
phipp85's Avatar
You should burnish the brakes to get the maximum performance from them. The procedure is in your owners manual and there is a sticky in the ZR1 section that covers the process pretty well. You should do it even if you don't track the car.
Old 08-16-2013, 06:33 AM
JohnAlley
JohnAlley's Avatar
Old 08-16-2013, 10:50 AM
CHJ In Virginia
CHJ In Virginia's Avatar
Congrats on the new ride. Your CC will take a serious hit if you ever have to replace the pads or rotors ! Follow the process in the owners manual for break in.
Old 08-16-2013, 01:38 PM
froggy47
froggy47's Avatar
I was looking at one in LA to buy. If I had I would probably replace the pads/rotors with equipment that is easier on the wallet to renew. Put the stockers back on to sell it.
If you are only going to autox it 3 or 4 times a year then They'll probably last a long time, but if you are going to be serious & maybe track it then research the cost of replacement & frequency.
Go to the c6zr1 forum & see if anyone tracks theirs.
To ZR1 rotors
Quick Reply: ZR1 rotors
