Annual maintenance suggestions for track C6
Old 08-24-2013, 12:18 AM
JonJ
JonJ's Avatar
Default Annual maintenance suggestions for track C6
I'm rounding the bend on the final straight to my first season with my new (to me) C6 Z51 and will have about 12-15 tracks days this year. I was trying to start looking into what sorts of things need to be done on the car at the end of the year. I have over a decade's worth of track driving so the track miles are pretty hard miles. Not quite race-car harsh but close.
Aside from changing all of the fluids, another nut and bolt, is anyone aware of any preventative schedule that is commonly adopted? I saw annual replacement of valve springs in one thread but was looking for some sort of a more comprehensive list.
My cursory search was unsuccessful, hence the post.
Old 08-24-2013, 04:28 PM
neilvosko
neilvosko's Avatar
should get a list together and should be a sticky
Old 08-24-2013, 06:27 PM
froggy47
froggy47's Avatar
Old 08-24-2013, 06:51 PM
dbratten
Support Corvetteforum!
dbratten's Avatar
OK, I'll start with one that becomes a problem -- pull your rotors off and check for hairline cracks forming around the hubs. Hubs have a habit of breaking at inopportune times on track and the only thing holding your wheel on is the caliper.
New SKFs are a solution.
--Dan
Old 08-24-2013, 08:16 PM
CP Thunder
CP Thunder's Avatar
Change your wheel studs every year especially if you are changing wheels and retorquing alot.
Examine the upper front control arm bushings as they seem to like to relocate themselves.
Check your brake pads for taper top to bottom. If thicker at the bottom....time to replace the calipers as they are splayed at the bridge.
Put the car in the air and check all four wheels for play holding your hands at 12 and 6, then 9 and 3. 9 and 3 wobble usually means rod ends, 12 and 6 usually means hub.
Check your spring adjusting bolts to make sure the rubber (or delrin) pad on the end is still there (Surprise!!! I found a broken spring bolt my last inspection)
Just a few of the things of the top of my head.....
Old 08-25-2013, 01:43 AM
JonJ
JonJ's Avatar
Perfect. This is the stuff I'm looking for. Thanks guys. SKF are on the list for next year. Anything else?
Old 08-25-2013, 10:53 AM
Gering
Tolero Apto Victum
Gering's Avatar
For me as well, here is a thread about them - http://forums.corvetteforum.com/auto...e-upgrade.html
Old 08-25-2013, 01:53 PM
froggy47
froggy47's Avatar
BTW I found the REGULAR SKF in an SKF box for $200 at NAPA. Preferred customer discount & all I did was ask for any discount.
The RACE SKF is better of course if you race, but for autox and DE IMO the regular is plenty.
Old 08-25-2013, 05:31 PM
dbratten
dbratten's Avatar
After my second OEM hub went out within two weekends I went to the race version of SKFs on all four corners. With all the time my car spends on big Kumho 710s it made sense for me to spend the extra money. The potential for time lost during a track day (where I lost half the day plus scurrying about to find a replacement hub on a Saturday) or in being trailered home from an autox on a Sunday by a friend convinced me the better hubs were the choice to make.
--Dan
Old 08-25-2013, 10:03 PM
froggy47
froggy47's Avatar
--Dan
Who makes the GM oem bearings?
I am on 4 of them with 55k miles.
Lot of a6 & 710 laps.
Old 08-25-2013, 10:44 PM
StKnoWhere
StKnoWhere's Avatar
Brake lines if older than 3 yrs or any sign of damage.
I've see enough reports of SS lines interfering with ABS/TCS I've been afraid to go that route.
Old 08-26-2013, 05:08 PM
naschmitz
naschmitz's Avatar
What?
Old 08-26-2013, 08:16 PM
dbratten
dbratten's Avatar
AC Delco is what I went with at first. I only had 30-33k on the two driver's side hubs that failed. I had laps at Big Willow and Buttonwillow CW courses on them plus autox.
--Dan
Old 08-30-2013, 07:10 PM
corvette95
corvette95's Avatar
Where can I get SKF hubs for my 1995 C4? Anyone have a 95 part number?
Old 08-30-2013, 08:41 PM
CONE RACER
CONE RACER's Avatar
Don't forget to check the motor and tranny mounts. For the motor mounts, they are filled with a dirty looking oil. When they start to leak, it shows up as a stain on the oil pan, so don't confuse it with an oil leak. (The stain is more black than brown.) Look for splits on the tranny mounts. If you do any AX as well, those events are particularly hard on both motor and transmission mounts.
Also, a big +1 on the brake lines. With 5 or 6 DE's plus 30 AX events per year, I replace mine every 2 years, even though they look fine from a visual inspection point. DE's put a lot of heat into the line at the banjo and the crimp. Even with good visual inspections, you can't see if the line is degraded under the crimp area. (I learned the brake line lesson - luckily at a low speed situation with an escape route available.)
Old 08-30-2013, 08:42 PM
MarkDFW
MarkDFW's Avatar
To Annual maintenance suggestions for track C6
Quick Reply: Annual maintenance suggestions for track C6
