F/S Dry sump system for LS ,, new
F/S Aviaid LS Block mount dry sump 3 stage system ,, 3 stage pump Block mount,,,, Aviaid Dry sump pan with integrated Screens,,,,, AtI super damper with HTD drive hub and drive belt... Everything is new ,, the pump and pan was installed on a motor for some test fit,, the AtI was never out of the box...
This system was going to be used on a road race motor build but I Later decided to purchase a new built motor that already had a dry sump system installed... only thing you will need is a dry sump tank ( Petterson,Moroso or get one made up to your specs) of your choice and a remote oil filter and you will be good to go...
Sold
Manny 305-333-4445
mannysanchez360@gmial.com
http://aviaid.com/schems/3sbddss.gif
[IMG][/IMG]
Sold
Manny 305-333-4445
[IMG][/IMG]
