My VIR Video Study Guide
Old 08-31-2013, 10:16 AM
naschmitz
naschmitz's Avatar
Default My VIR Video Study Guide
Merged a video of my best lap with Mark Nunnally's posted 2:02 lap. Used RaceRender to re-align the cars and measure the gaps along the way.
Besides the difference in driver skills, my car is not a T1 car and I'm not on A6s either. It's a daily driver on R6s that classes NASA TT3 (374rwhp and 3350lbs with the +0.05 adjustment makes 9.0lbs/hp.) I'd be willing to bet Nunnally could do a 2:05 in my car.
Left channel audio is my car. Right channel audio is Nunnally's if you want to isolate on something.
Old 08-31-2013, 10:06 PM
JeremyGSU
JeremyGSU's Avatar
That's pretty cool how you did the comparison. In watching it though based on the video it doesn't seem like you're 6 seconds behind. You almost look neck and neck with him. Cool vid.
Old 08-31-2013, 10:16 PM
drivinhard
Support Corvetteforum!
drivinhard's Avatar
I had to try the 245 tire thing just to see what it did, pretty big drop off in braking and turn in grip. The experiment "worked" because of the give-back you got for running small tires (run the car lighter, closer ratio gearbox, much better power to weight - something around 8:1 actual, 8.7 adjusted). It was pretty fast in a straight line, but it was not a very good all around set-up.
Looking forward to this Oct
Old 09-01-2013, 12:00 AM
naschmitz
naschmitz's Avatar
After each segment I re-aligned the videos using RaceRender's synchronization tool and tallied up how much time I lost. So at the end I am within a second, but have already advanced my video by more than five seconds total.
Old 09-01-2013, 09:45 AM
naschmitz
naschmitz's Avatar
245s in front or on the rears too?
I don't know if 245s could be stretched beyond their spec'd rim widths to even fit on my wheels -- hell the C6 base coupe non-GS non-Z06 stock rear wheels are outside Hoosier's recommended widths.
Old 09-01-2013, 10:12 AM
drivinhard
drivinhard's Avatar
245/40/17 on C5Z front 17x9.5" wheels
245/40/18 on base C5 rears 18x9.5". Fit is about like a 275/18 on a 10.5" wheel
Old 09-01-2013, 10:59 AM
Falcon
Falcon's Avatar
When I watched the clip there was some kind of voice track overlaid occasionally, was that intentional?
Old 09-01-2013, 11:39 AM
naschmitz
naschmitz's Avatar
Sound clips from the 1979 movie Alien to go with the tally of lost time. Thought it might stress the futility in the comparison to a better driver. Guess not LOL!
Old 09-01-2013, 10:31 PM
drivinhard
drivinhard's Avatar
are you running in TT w/ NASA in Oct?
Old 09-02-2013, 07:22 AM
naschmitz
naschmitz's Avatar
I've considered it, but have never run with NASA so I'm not sure what hurdles I'd have to clear. I have an active TT license with COMSCC and the amb transponder. Dyno sheet is years old but I haven't touched the motor so my HP numbers shouldn't be a problem other than getting them taken somewhere. Had the car corner weighted last year so the weights should be good too.
What would be the next step? Do I call the MidAtlantic guys to find out how to clear these hurdles or the SouthEast guys since I live in NC?
Thanks, Bert
Old 09-02-2013, 07:38 AM
drivinhard
drivinhard's Avatar
Thanks, Bert
email this guy: jfelton@drivenasa.com
To My VIR Video Study Guide
Quick Reply: My VIR Video Study Guide
