My turn. Ripped axle boot.
A very small rip less then a 1/16" right near the big clamp side. On the edge. Any ideas on fixing it?
Thanks,
Steve A.
Thanks,
Steve A.
It looks like the boot is attached with metal crimp on "zip ties" like the kind that are on the front steering rack boot.
There is a special tool to make the crimp they sell for about $50. CV boot clamp pliers or something like that. Or you can try squeezing the clamp with needle nose maybe. If you squeeze too tight the metal clamp breaks, so not too tight.
You just break them off to remove.
I repaired a front steering rack boot with silicone tape & zip ties, it had worn thru from contact with the big sway bar.
Of course that boot doesn't spin.
If it's near the clamp you could try cleaning it up, regrease, wrap the tear with silicone tape & put new clamp on. You would be clamping the torn part up against a solid part of the axle.
If it were in the middle, I think a new boot is needed, only oem are any good from what I hear. If you can get just the boot.
Here's my two cents worth....Also I have started using Big zip ties to hold the large side of the boot and with the axle boots I use you don't clamp the small side.
http://forums.corvetteforum.com/auto...nce-issue.html
Thanks guys for all the tips. If I replace just the boot, how do you take the CV joint apart? I can get the axle out, but that's all I know. "geerookie" are you saying just plain old zip ties? How do you tell if their quality ones?
thanks,
Steve
thanks,
Steve
I rebuilt the CV on one of the rear axles on my C5Z. Hindsight says it would have been easier and better to just buy a new axle. They are a bit more than $100, but rebuilding and re packing the CV is a pain because of the special crimp you have to do. If you do that route, just rent the tool from a parts shop.
Here's what I use for ties
http://www.mcmaster.com/#7130k942/=obgefm
But you can also use these....they are a bit wider but plenty strong.
http://www.homedepot.com/p/36-in-Hea...4#.UiNFNTZwofc
Track Junky
I've used some form of glue (gorilla glue, goop) them wrapped that strechy silicone tape that attaches very well to itself (the stuff that repairs leaks on plumbing and garden hoses) over the top of that. It lasted 2 years+ of track days and hasn't shown any signs of coming off yet.
Okay guys, this is what I came up with. I cut the metal band and re-greased the inside. Still had a lot of grease in it. Put a big zip tie on to hold the boot back in place. Since the cut is right on the edge, I put another zip tie over the cut with silicone. Then I used some 5 minute epoxy to cover the small rip on the side of the boot. I'm sure your laughing but it might work. In reality, I'm sure I'll be buying another axle soon. Thanks for all the help.
Steve A.
Steve A.
I just replaced a boot on my track-only Z06. I went with a DriveShaft Shop OEM 2010 Camaro boot and it was pretty straightforward. Knocking the halfshaft apart is unnerving as Greg (geerookie) mentioned, but there was nothing to it. I ran the car hard at VIR this weekend and everything looks good.
BTW, Advance Auto sells the crimp tool for $9.99. You don't need anything more. The next time I do it, I will just ziptie it as Greg also suggested.
If any of you are suggesting to get a $100 aftermarket halfshaft and put it on a track car, you must have never seen how the cheap aftermarket CV boots balloon out under speed and heat and grab the brake lines. If you have ever witnessed this, you would understand the dangers.
-Kevin
-Kevin
I just rebuilt two axles yesterday. The first took an hour (learning curve). The second took about 20 minutes. The clamps are the biggest pain in the A$$. The rest is easy enough. Do a search for 'RESCUE TAPE'. The stuff is awesome. It saved us at the SCCA June Sprints this year when we tore a boot. Twice. We like it so much we contacted the business and we are now a distributor.
DO NOT use O'Reillys type replacement axles if you track your car. The boots are SOFT and EXPAND at high speed and hit things they aren't supposed to hit and really make a mess. (Ask me how I know this). They will fail EVERYTIME if you put the car on a dyno. (Ask me how I know).
