Any Upgrade suggestions while engine is out?
Old 08-31-2013, 07:44 PM
Searya
Searya's Avatar
Default Any Upgrade suggestions while engine is out?
I am having my engine pulled to refresh it. The engine is already built but I was wondering if there are any other upgrades that i should do while the engine is out?
I use the car a little around town but primarily for track days.
Thanks !
Old 08-31-2013, 07:52 PM
VGLNTE1
VGLNTE1's Avatar
St. Jude Donor '14-'15
Solid Motor mounts, clutch, speed bleeder
Old 08-31-2013, 09:20 PM
froggy47
froggy47's Avatar
Torque tube bearings/couplers.
Old 08-31-2013, 10:10 PM
JerryTX
JerryTX's Avatar
Heat wrap (or coat) the headers, and heat wrap all the clutch lines as well as all the lines around the starter.
Old 09-01-2013, 01:30 PM
Searya
Searya's Avatar
I put in a new clutch (RPS BC2) and speed bleeder last year so all set there but I will definitely check out the clutch while it is out.
I have thought about swapping the motor mounts what benefit do they give you?
Old 09-01-2013, 01:32 PM
Searya
Searya's Avatar
I hadn't heard of Torque tube bearings and couplers. Is that an improvement item (and if so what does it help with) or just good maintenance to do while in there?
Old 09-01-2013, 01:34 PM
Searya
Searya's Avatar
Thanks I will plan to do that. Do most folks go ceramic or heat wrap?
I will also wrap anything else I can. Hopefully it will get rid of the crazy vibration rattle I hear when accelerating hard!
Old 09-01-2013, 03:46 PM
CHJ In Virginia
CHJ In Virginia's Avatar
There are two rubber based couplers (guibos) on the drive shaft inside of the torque tube. They tend to crack then disintegrate when under heavy stress ftom tracking the car. Very good maintenance practice to inspect couplers and bearings in TT as long as it is apart and out of the car. You could save yourself a big headache and lots of cost / time later by catching the problem early.
Old 09-01-2013, 05:58 PM
Searya
Searya's Avatar
Thanks I will check/replace the couplers when the engine is out.
Old 09-15-2013, 04:32 AM
morris
morris's Avatar
My couplers went out at track attack last month, definitely inspect or replace them while its out. Second I would go ahead and replace the tick master / slave cylinder Katech has a complete kit.
Old 09-15-2013, 10:06 AM
Searya
Searya's Avatar
Thanks I will check out Katech.
Did you end up going with the stock couplers when you fixed yours?
Old 09-15-2013, 11:26 AM
redtopz
redtopz's Avatar
Some good ideas here. I'm going to finish insulating the top of my tunnel to keep the heat out of the cockpit as much as possible. I don't like using cool suits. It's also a good time to inspect and replace brake lines if needed. And inspect all your wiring. I just dropped my engine yesterday to start working it.
Old 09-15-2013, 11:30 AM
0Randy@DRM
Former Vendor
Randy@DRM's Avatar
Very easy upgrade with the cradle out like that.
http://dougrippie.com/products/drm-s...ack-bushing-2/
Randy
Old 09-15-2013, 11:56 AM
morris
morris's Avatar
Those things letting go wound up costing thousands in repairs the second day I got it back after a complete engine build, I wasn't happy. I think I will replace them every year or two moving forward, depending upon how often I have the car torn apart. with a 30 hour engine refresh schedule it should work out to be good timing any way. I went with the stock units, it is my understanding that that's all there is unless you want to gomwith some sort of solid piece, which would transmit entirely too much vibration
Old 09-16-2013, 12:30 PM
waddisme
Support Corvetteforum!
waddisme's Avatar
I have one stock one and 1 aluminum one in mine. 2 al ones would be too much vibration I was told.
Old 09-17-2013, 03:02 PM
Gering
Tolero Apto Victum
Gering's Avatar
Randy
Sir,
Would you see any benefit on the street for a DD?
Old 09-17-2013, 03:37 PM
froggy47
froggy47's Avatar
Originally Posted by Gering
Sir,
Only if you want your steering to be a touch more precise. If you have grown fond of the rubbery feel then leave it out.
To Any Upgrade suggestions while engine is out?
Old 09-17-2013, 04:20 PM
Gering
Tolero Apto Victum
Gering's Avatar
Ok, thanks.
Old 09-17-2013, 04:49 PM
0Randy@DRM
Former Vendor
Randy@DRM's Avatar
It really depends on the age and condition of the factory rubber bushing. Some of them are so bad that it makes a huge difference.
Randy
Old 09-17-2013, 09:30 PM
Gering
Tolero Apto Victum
Gering's Avatar
Randy
Randy@DRM & froggy47: Thanks for the info, item just ordered!
Quick Reply: Any Upgrade suggestions while engine is out?
