Wheels & Tires Corvette Wheel & Tire Sizing Info, Staggered Fitment, Tread Compound, Tire Pressure, size option
c5 17x11 36mm offset square setup?
Old 09-01-2013, 12:36 PM
TBuskey
TBuskey's Avatar
Default c5 17x11 36mm offset square setup?
I have a set of 17x11 zr1 wheels with the 36mm offset with 315-35 nitto nt01 tires for autoX. I used these for a square setup on my 4th gen camaro. I have found that most people recommend the 50mm offset for fitment on the C5, But say it rubs slightly on the front arms and brake ducts. Should I put the 36mm for sale or run them on the C5? Does anyone run the 36mm square offset on C5? *This is for track use only*
RUN THEM OR SELL THEM FOR A 50MM SET?
Old 09-22-2013, 06:52 PM
cwikstro
cwikstro's Avatar
The 36 mm will stick out if you run them on a C5 but will fit. Those will fit a 84-87 C4 square. I run these on mine. Hope this helps.
Quick Reply: c5 17x11 36mm offset square setup?
