Is this tire OK to use?
Old 09-16-2013, 11:21 PM
waddisme
Support Corvetteforum!
waddisme's Avatar
Default Is this tire OK to use?
It is a Hoosier R80. I can't tell if it is worn or just rubbed on my fender. It is only in that one spot. Should I just trash it and move on?
[IMG][/IMG]
Old 09-17-2013, 12:16 AM
GT Racing Tires
Supporting Vendor
GT Racing Tires's Avatar
DONE! Will cord very quick.
Old 09-17-2013, 12:42 AM
waddisme
waddisme's Avatar
Thanks. To the tire heap,
Old 09-17-2013, 09:52 AM
CHJ In Virginia
CHJ In Virginia's Avatar
Tire is toast ! That area showing cords will spread VERY quickly.
Old 09-17-2013, 04:40 PM
geerookie
geerookie's Avatar
It's still usable.................................. ..as a tire swing for the kids!
Old 09-17-2013, 04:51 PM
brkntrxn
brkntrxn's Avatar
Two weekends ago, I won Time Trials with a 2:10 at VIR Full on four 275 R6s that looked worse than that. Ran the first lap hard, backed off the second lap, ran the third lap hard, and on the fourth lap I drifted T1-T4 so much that I left smoke.
The "ok to use" threshold depends on your individual budget.
Old 09-17-2013, 05:05 PM
Solofast
Solofast's Avatar
We used to run test sessions on older steel belted tires like BFG's and Goodyears and run them to where they had cords showing all the way around for a one inch stripe... After sitting for a day or so the tire would deform and be totally unusable, but you could run them till you got thru the top layer of steel belt and they were still fast...
Hoosiers aren't that robust. If you are on a real road course (and not an autocross) with a corded Hoosier you are only good for a few laps and after that you are going to lose the tire... I've generally run them past where the OP is, but if you can see a stripe all the way around you need to be parking them.
I wouldn't start a 20 minute session with that tire, it's not likely to make it.
Old 09-17-2013, 06:50 PM
froggy47
froggy47's Avatar
I wouldn't track it, but I'd flip it & get some autox runs.
Old 09-17-2013, 10:00 PM
dvandentop
dvandentop's Avatar
wont last a session so dont throw one down precious track time over a bad tire.
would be ok for a few auto x runs probably
Old 09-20-2013, 03:06 PM
EyeMaster
EyeMaster's Avatar
You won't get more than 2 or 3 autocross runs with this, and it won't get you your best time. Good to practice with. If it's the rear tire, time to play with the rear end a bit and do an agressive autocross run. (safely...)
Old 09-22-2013, 10:51 AM
brkntrxn
brkntrxn's Avatar
Took a picture of said tires. You people thought I was joking, didn't you? I refuse to take a tire off the car until I can hear metal.
Old 09-22-2013, 05:43 PM
Mike.D
Mike.D's Avatar
i like your style, but dont you get scared of a blow out at high speed?
Old 09-22-2013, 07:49 PM
RaleighSS
RaleighSS's Avatar
Ok ... I hear ya and respect your decision to continue to run corded tires to stay in budget but ya have to know that tire is at much greater risk for failure or at least very unpredictable handling . If I cord, my day is over and I am done until i can spot the 400 for 4 more scrubs. The class I run in has no purse ... no trophy ... no nothing so not worth the risk for me ....
Old 09-22-2013, 08:02 PM
brkntrxn
brkntrxn's Avatar
No. I you are really in tune with your car, you can feel from the driver's seat at speed which tire has corded and whether inside or outside. You can then adjust your driving style to protect the tire.
Corded front inside? Lighten up on the braking and trail brake more to we the outside of the tire. Etc etc etc.
To Is this tire OK to use?
Quick Reply: Is this tire OK to use?
