Need c5z corner weights - stock
Old 09-25-2013, 08:17 PM
froggy47
froggy47's Avatar
Default Need c5z corner weights - stock
If you have some stock c5z corner weight data, and especially if you have the weights for a 2004 Commerative (hood was CF and lighter by about 12 - 15 lbs.
Please post the weights up & thanks. Before balance weights.
Old 09-25-2013, 11:41 PM
acrace
acrace's Avatar
Corner weights, totally stock, for a 2003 Z06 - with full tank of gas and 150 pound driver weight - before adjustments (as requested by you).
LF: 880 lbs
RF: 875 lbs
LR: 797 lbs
RR: 752 lbs
F/R = 53.12%/46.88%
L/R = 50.76%/49.24%
Cross difference = 40 lbs
Old 09-26-2013, 12:01 AM
froggy47
froggy47's Avatar
Thanks,
any more just to compare?
Old 09-26-2013, 07:44 AM
Scooter70
Scooter70's Avatar
My 2001 Z06. Full interior but with Cobra Suzuka race seat on driver's side, Hardbar, and harness. No driver, 1/4 tank of gas. I've never messed with ride heights or corner balance on it but when I bought it it was lower than stock.
Front to rear:
Cross:
Total:
Old 09-26-2013, 10:02 AM
joenationwide
joenationwide's Avatar
Front to rear:
Sorry to thread hijack, but my E36M3 had the same weight distribution (heavy LF, light LR, and almost identical RF & RR that were just below the avg. of the LF & LR).
I bet you go through LF rotors fast too.
Is it possible to corner balance this close to 50:50 F-R and L-R without moving weight around in the car?
Old 09-26-2013, 10:06 AM
2MCHPWR
2MCHPWR's Avatar
my previous car. 2002 z06
http://www.ponycars.net/images/z06/z06corner.pdf
Old 09-26-2013, 03:36 PM
BEZ06
Support Corvetteforum!
BEZ06's Avatar
Here's my buddy's 2004 Z06 on the scales in the NASCAR tech shed at Daytona.
He was not in the car, I think it was about 5/8 to 3/4 tank of gas.
From top to bottom it's LF, RF, RR, LR.
Bob
Old 09-26-2013, 03:53 PM
froggy47
froggy47's Avatar
Bob
Thanks!
Old 09-26-2013, 05:10 PM
fatbillybob
fatbillybob's Avatar
This was factory stock. Can't remember how much gas car empty. How do you like those numbers?
Old 09-26-2013, 05:30 PM
Shaka
Shaka's Avatar
Received 1,331 Likes on 790 Posts
If you don't have a roll cage, place the car on the scales with you or a weight on the seat. Roof in place if it is not a Z06.
Note readings and ride heights at each corner.
Jack the car from the center of the rear sub frame and remove rear scales and lower the car to the ride heights noted. Check front scales and ride height. Adjust ride to original height if it has changed which you probably won't have to.
Do the same for the rear.
Weigh car again and check ride heights. Adjust corner weights to the original readings with rear adjustment.
This ensures that there is no energy in the frame. From this base, you can move stuff around as best you can to achieve as close to the the numbers shown in the BEZ06's last post as possible.
You may be pleased if you achieve these numbers in another way but you may end up with an energized chassis ( Twisted frame) which will will make shock tuning difficult and alter spring rates.
Old 09-27-2013, 12:15 AM
acrace
acrace's Avatar
Don't forget to disconnect the sway bars.
To Need c5z corner weights - stock
Quick Reply: Need c5z corner weights - stock
