Getting ready to buy Weld S71 wheels, need proper size confirmed
I am looking at buying a set of 18" (front and rear) Weld S71 wheels. Just want to get the correct offset and backspacing numbers before I hit the buy button. The numbers I have from Welds website are :
18x12.0 S71 5x120 7.6BS(28mm offset) Black 3.18ID High Pad for the rear
18x10.0 S71 5x120 7.1BS(41mm offset) Black 3.18ID High Pad for the fronts.
Can someone confirm these are the right sizes, I plan on running drag radials, car is lowered on coilovers if that makes a difference.
