Wheels & Tires Corvette Wheel & Tire Sizing Info, Staggered Fitment, Tread Compound, Tire Pressure, size option
2006 offset questions... knowing stock is +56 rear +79
Old 10-16-2013, 10:09 PM
Badbluebird
Badbluebird's Avatar
Default 2006 offset questions... knowing stock is +56 rear +79
will these be a terrible fit?
Size: 18x8.5 Offset: 46.0
Size: 19x10 Offset: 65.0
also should and can i go 10.5 rear without changing tires?
thanks for any and all help
Old 10-16-2013, 11:02 PM
realcanuk
realcanuk's Avatar
St. Jude Donor '13
Use this calculator to show you exactly where then wheels will sit.
http://www.1010tires.com/Tools/Wheel-Offset-Calculator
Old 10-16-2013, 11:26 PM
Badbluebird
wish i could understand that before, definately not a wheel guy but thank you
Old 10-20-2013, 06:18 PM
jon6.0
jon6.0's Avatar
This site is better: http://www.rimsntires.com/specs.jsp
You put your current wheel and tire size in along with your new wheel and tire size. It will then say how much farther in/out or bigger/smaller the new wheel/tire is.
The 245/40-18 on a 18x8.5 +46 will be .4" farther out toward the fenders. That will work.
The 285/35-19 on a 19x10 +65 will be .6" farther out toward the fenders. That will work.
I wouldn't recommend running a 305 in back with those wheels. It will rub or stick out too far as they would be .9" farther out.
Old 10-20-2013, 07:33 PM
Badbluebird
thanks , im running stock sizes...so i should be safe?
Old 10-22-2013, 10:24 PM
jon6.0
jon6.0's Avatar
Should be good.
To 2006 offset questions... knowing stock is +56 rear +79
Quick Reply: 2006 offset questions... knowing stock is +56 rear +79
