Wheels & Tires Corvette Wheel & Tire Sizing Info, Staggered Fitment, Tread Compound, Tire Pressure, size option
Consumer Reports: Quick Flat-Tire Fixes
Old 11-08-2013, 10:40 AM
0Luke@tirerack
Former Vendor
Luke@tirerack's Avatar
St. Jude Donor '11-'12
Default Consumer Reports: Quick Flat-Tire Fixes
Almost every new car used to come with a spare tire, but these days spares are no longer standard. And even if you have a spare, changing a tire is no fun.
Consumer Reports tested tire-sealant compressor kits, as well as aerosol cans that promise a quick fix. To test, a car was outfitted with 15-inch, all-season tires and one of the tires was punctured with a small nail.
All of the aerosol cans were able to seal the small hole and inflate the tire, which kept going for more than 100 miles. But Consumer Reports found that all of the cans had difficulty with larger holes. And because an aerosol can is under pressure, you can't keep it in your car in hot weather; it can explode. So that kind of limits its use. You're not going to keep it in your car. You're probably going to keep it at home. And when you need to use it, it's not going to be with you.
The compressor units are more expensive but can be safely stored in your car. You plug the compressor into your car's power adapter and attach the sealant canister to your tire. All of the compressor kits fixed even larger holes. They also come with a gauge to make sure you're inflating to the recommended pressure. Consumer Reports found that the $80 Continental ContiComfortKit works the fastest and has enough sealant to repair a wide variety of tire sizes.
Consumer Reports cautions that tire-fix products are just a temporary fix. As soon as you use them, get to a service station to have the tire inspected, repaired, or replaced. Also be aware that none of the products can repair very large punctures. And they should never be used to fix punctures in the sidewall of the tire.
Old 11-17-2013, 03:13 AM
geewez
geewez's Avatar
All the manufacturers say it's safe to use the aerosol cans of sealant but all the tire guys I've ever spoken to say don't. They say the can fix a flats will coat and ruin the TPMS. So what's your opinion Luke?
Old 11-19-2013, 05:35 PM
0Luke@tirerack
Former Vendor
the aerosol flat repair products will ruin tire pressure sensors. The material that is used in those cans is very caustic and very hard to clean up. In many cases it can make repairing a tire virtually impossible. Most techs do not want anything to do with a tire that has been filled with one of those products.
Old 11-22-2013, 05:32 AM
geewez
geewez's Avatar
So my 2009 Dodge Challenger doesn't come with a spare tire. Instead, the factory supplies a small compressor that has a can of fix a flat attached. If I get a flat, it's better not to use what Dodge supplied?
Old 12-17-2013, 07:05 PM
strand rider
strand rider's Avatar
Any reports about the Slime brand of tire sealant?
They are billed on the bottle as tire sensor safe. Cleans up with water, at least the fresh stuff I spilled washed off easily. Looks quite different than the pressurized stuff.
If you ever want to get a dirty look, Take a tire in with a can of sealant in it, and tell the guy at the tire machine it's your tire.
To Consumer Reports: Quick Flat-Tire Fixes
Quick Reply: Consumer Reports: Quick Flat-Tire Fixes
